  • Replies 354
Yup sure do Damo
so far we have the following people that i have received entries from. (they have been sent aswell)
white r34 - cara
white r34- damo
white r34- troy
silver r34 - luke
white r33 - vu
white r33 - alex
silver r33 - krishy
blue r32 - carl
white/black r32 - chris
dark blue r32 gtr - dan
thats all so far
still waiting to hear back from Wayne with a black r32 gtr, shaz with her grey r32 and danai with with red r33
as far as i know ruby will be entering the black stag and james with his r33 :bunny:
Edited by MissR34
http://www.nowetcarclean.com.au/page.asp?parentid=4
For those who are wondering about the packages these are the ones that they have.. BUT I will be in discussions tonight on how much we could do them for instead of the marked price :bunny:
Dont worry about stickers, there is no wax involved.. it should all be on the site in detail of what the products are etc.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
