Old School N New Age Show
MissR34
 Share
  • Replies 354
do we need a babysitter for it? If minibats posts up prices, everyone can choose whether or not they want it done on the day? Id say there will be at least 5 of us wanting it done? Who else is interested?
id be just interested in getting my interior done more or less............i dont like anyone touching the outside of my car due to the graphics..........ive had issues in the past where ive had a cut and polish done (this was just before autosalon 07) and the guy that did it left all polish in my stripes that i had on at the time...which then caused parts of them to lift :down:
but i use Permaguard anyways and im really happy with that :D
but will depend on price tho :)
and shaz thats ok u should enter anyway..............im sure we can work out someway to mask the damage that was done
u'd have to hide from the rear wheels back! haha n i'd needa find some spacers so that my car actually looks like it has rims n not floating
Edited by SHYGRL
lol SAU needs a babysitter fullstop, with half the whinging babies that are on here sometimes.
I couldn't understand why ABC went bust really ... there wasn't a lack of babies for sure :)
can I pick out my baby sitter...lol and I have been pushing today to get Aberax to get into the show, come on abe you know you want too.lol
Going to have to pull out Cara,
I have a formal & Afterparty on the friday and will probably still be up drinking by the time you guys head off to the show.
Sorry.
... For some reason my ears where burning the other night...and it wasnt from sunburn, now i know why :D
I'll ask the boss tomz, if i remember, if i can have that day off.
Sorry.
:D
lol
this is just one of those shows that is on a saturday and not a sunday like the rest of them, but im pretty sure it was on a saturday last year too.....
 Share
    • Great write up. I was thinking abt getting the niftycity for my g37 the aliexpress links u shared r not working anymore. Can u share again please?
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
