Old School N New Age Show
MissR34
 Share
i think we need some more coloured cars tho............too many white ones lol :(
you forgot me cara lol.mines red does that count haha? im heading out north today so i can probly meet you somewhere and pay and sign the form.msg me today at some point.
  • Replies 354
im so sorry i totally forgot to add u to my list!!!!!!
can you write me a letter explaining what this show is about im going to try and get a permit and the letter may help if not i wont be about to come matty cant tow me
Umm, I been real busy and forgot about this ... :P
Can I still get in Cara? I'm assuming I'd have to lodge my own form and identify I'm with SAU?
if u come to vilis on friday night ruby ill grab it off of u then.......i have to get someone else form that night so i can get urs too at the same time and ill send them in
Excellent. See you then blow girl :D
blow me hard and fast ruby :down:
When the gear knob just isn't enough anymore :P
:D
Still featuring that big knob at the this car show? ... along with the new doof doof!
Edited by RubyRS4
SAU:SA, disturbing the shit out of you and me since 24/3/2007.
Gutter minds can do that to you.
Only last week I was talking about my erection.
(the house extension erection that is ... mods don't ban me!) :D
Edited by RubyRS4
OK GUYS AND GURLS
we are just over a week away now from the show.............yes not this weekend but the next.......
i will be taking any final entries this friday at vilis..........i will try and be there at about 7-7.30pm
i will have entry forms with me
So far our entrants are the following:
Me - White R34
Troy - White R34
Luke - Silver R34
(now a tentative) Damo - White R34
Vu - White R33
Alex - White R33
Krishy - Silver R33 (yes/no??)
Anthony - Black R32
Carl - Blue R32
Chris - White/Black R32
Dan - Dark Blue R32 GTR
Shane - White R32 GTR
Ruby - Black Stag
I need to know ASAP what the following people are doing
James - Black R33
Krishy
Jack - Red R33
IT IS NOT TOO LATE TO ENTER!!!! IF YOU ARE THINKING OF ENTERING JUST MEET ME AT VILIS THIS FRIDAY NIGHT AND I CAN SORT YOU OUT WITH A ENTRY FORM......I WILL SEND THE FORMS OFF YOU DONT HAVE TO WORRY ABOUT DOING THAT
 Share
    • Great write up. I was thinking abt getting the niftycity for my g37 the aliexpress links u shared r not working anymore. Can u share again please?
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
