Cheap Gtr For Sale
the car was purchased in 2006 and was imported in 2005 by brisbane street machine, The car was sprayed bayside blue in japan and was used as a display car in japan from what i was told.
The car has every mod to indicate that its a nizmo build. Diff,No abs,no rear wiper, VIN number, rear drilled brakes, front bar, boot lip under spolier, dash has also a carbon fiber lip on the bonnet..
AS mentioned the head was recently redone also Z32 air flowmeters installed. The car requires a dyno.
If someone is interested ill let them have it for 16 grand as is.. No plates and will require a dyno. I have a 3inch cat to be installed however i have not had time to get it installed as im very busy with work.
All inspections are welcome its just sitting here in my shead all polished up.
Reason for sale is because im in the Defence force i hardly drive it im always away from home and could very well be going overseas again soon and i dont want to leave it in storage or in a carpark.. This car has never been on the track. The drive shafts have been redone and last week new springs installed. new tires on the front etc.
I understand that the price of imports have gone down and anyone could get a half decent 32 GTR for around 16/17 now however 16 is the lowest ill go.
I will sell the car minus rims,computer,coilpacks,head unit subs and amp. for 13,000 ill install standard coil packs and try locate rims for it to be transported. Power FC will be required for the running of airflowmeters.
THere is a few options for people..
16000 take it away or
13000 take it away minus mention parts.
Cheers.
  • Replies 50
Posted Images
Hi,
I am located in Perth, and looking and ready to buy.
Can you please email me pictures of the car both side views, front, rear, engine bay, boot and interior.
As far as I am aware, all 1990 Nismo GTRs were produced in Gunmetal Grey. Has this car been resprayed and if so when?
Please reply to my email address: [email protected]
I am serious buyer.
Gan
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
