Remove drivers side front wheel,then you`ll see your wheel arch liner that covers the inner arch.The back section comes off by the 3 screws attaching it to the wing,a couple off push in trim clips and a screw on the sill bodykit piece.Behind that you`ll see a big rubber grommet going into the car (bulkhead area)just push a new hole in it or squeeze new loom/boost sensor tube through with the main loom into the car,they`ll appear next to the throttle cable area.
i ran my boost lines on the drivers side (look in engine bay) on the firewall you should see existing cables running into a grommet and the wires then run under your wheel arch into the engine bay..
i can run the boost cable there, but im putting in a new solanoid to and the cable wont reach( and i dont want to cut them to make them longer) so i trying to find something a bit closer
hey thanks for the replies, i was looking around for ages and found that on the passengers side there is a box in the engine bay which is the abs system, behind that there is a gromet which the the ecu cables run through.
