Yes, another r32 for possible sale but better than the rest! :uh-huh:
1993 gunmetal grey in excellent condition and always regularly maintained by obsessed owner, im only thinking of selling simply for a change as i have had this car for over 5 years now, there is not a single thing wrong with it!
Over that time anything that could or need to be replaced has been, with a few extras :D
The car has 89,000 genuine kilometres, and is stock in terms of appearance, always been garaged so paint in excellent condition.
Interior also in excellent condition.
Maintenance;
Mobil 1 every 5000kms for 3 years, now Pennzoil semi synthetic, running bendix ultimates brake pads, motul gearbox oil, air con regassed, castrol srf brake fluid, upgraded clutch, dynoed at 132rwKw 1.5 year ago (stock!)
Suspension Mods;
Cusco front/rear strut braces, full whiteline suspension kit handles awesome :) still good ride (sway bars, bushes, shocks, springs)
Engine Mods;
Trust Airinx hotair pod filter ;p, apexi avc boost controller, full exhaust, boost gauge, gtr fuel pump, ecu chip remap to suit turbo and pump, brand!! new r34 turbo (has done 2000kms now on this car) (nothing wrong with old turbo just wanted more go!), a shitload faster than before but still similar boost response, around 175rwKw, hasnt been dynoed yet but air/fuel ratios checked and all nice and safe...New turbo never boosted above 13psi...
Other stuff;
CD player, amp, speakers, dual alarms
Will trade for MX5 seriously! Price $16000
Sydney only.
PICS BELOW
https://www.sau.com.au/forums/topic/25751-fs-best-r32-gts-t/
  • 2 months later...
hey
just run the nissan oil
ive tried pennz semi synth
mobil synth s
shell eco10 semi synth
and shell fully synth
worst was shell fully synth then eco10 , synth s , penzzoil
and the best is nissan special blend
and it only costs like 34 bucks for 5 ltrs!
oil pressure sits perfect
https://www.sau.com.au/forums/topic/25751-fs-best-r32-gts-t/#findComment-634241
nissky,
Sorry to see you out of the nissan game but let me know what you get and on my next trip to Japan I'll bring back some goodies ( like that R34 turbo ) to tempt you with :rofl:
https://www.sau.com.au/forums/topic/25751-fs-best-r32-gts-t/#findComment-646134
  FAT32 said:
nissky,
ill be around here somewhere, and back in a nissan one day :O .... and theres a new guy on here with my car
hey next time your in japan, bring me a turbo kit for an mx5, i think it should fit in your hand luggage haha
https://www.sau.com.au/forums/topic/25751-fs-best-r32-gts-t/#findComment-646360
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
