Hey Guys,
I'm building up the D-Project / Driftshop R32 4 door drift car and I have some goodies for your car that I dont need.
The car was imported for parts ages ago and was only driven on the road with trade plates.
Nothing special here in terms of performance - but at least you have a decent option if you have blown a motor etc.
RB20DE Engine complete w/Inlet/Exhaust manifold, Loom, etc - 110,00 kms (will confirm) - $750ono
RB20DE Auto Gearbox - Drives like it is still new - shifts hard - $250ono
R32 4 door Interior - Complete - $400
Front/Rear/Roof/Door Trims/Dash/etc - from $49 a piece.
Dash Cluster (will update kms) - $49
4 Door Power window regs - $49ea
4 Door window glass - $49ea
Bits of loom / interior wiring / switches- from $10
Basically the car is getting stripped down to a bare rolling shell with all panels and no engine/driveline/interior and going on a massive weight reduction for the track.
I can freight all around Australia - however things like engines and so forth will need to be put on pallet for transit.
Post up what you need in the thread and I will get back to you on a price. I can freight non engine/gb stuff anywhere in Australia.
Pics TBA.
duno if its the same thing as chris wants but i need the rear passenger piller trim where the seatbelt comes through
as long as its not broken
Thanks for the messages guys. I will take photos in and out of the car for you.
I will confirm the rest of the details thursday/friday.
The goods will be sold on a first come - first serve basis.
I also have all the seatbelts which should be in very good condition.
4DR R32 - From memory the dash and console is 100% ok no cracks etc.
CeJay - just to confirm - You are after the plastic trims that are between the windscreen and front door.
GTST-Sedan - That part is available.
AC System parts also available - great if you have had a front end stack!
Simonster - It will be sold - but it will be one of the last things to sell as I need to find replacement plexiglass and need access to the windows so I can move them up and down. If you dont mind waiting 2-3 weeks - its yours for $35 delivered.
GTS-T_Sedan - C Pillar Trims - $25 each + Freight. Are you after left or right or both?
Yes I'm after the plastic strip between the windscreen and the door, that goes from the dash to the roofliner. (Think it's the called the A pillar) Not interested if they are damaged though, as both of mine are broken and brittle on the top section.
Also the rear seats, but only if they are the velour.
Might also be interested in the passenger side belt buckle, but thats depending on what it looks like.
thanks
I m after the dash if its in good condition? also parcel shelf and may be some rear trims if they are not gone..
giving you a call tomorrow regarding pick ups
thanks
yeh just need the passenger side one
will you be at the SAU renewal day on saturday at Kamakazie?
if so ill be there instead of posting it
otherwise ill have to get it posted
edit: also do you hav ethe door scuff plates in gc?
how much for the set?
Ok guys,
I've had a few PMs and orders and I will be stripping the car late next week provided the weather is good.
Everything on the car is 100% good, but I may break it removing it. I will let the interested parties know the condition after I have removed it. 15+ year old plastics tend to be very fragile at the clips.
The interior is NOT velour as it was a non turbo - RB20 spec car.
Please do not call me regarding the parts on the car. PM or post here..
I do not want to be called for the simple fact that there are at least 10 people after parts and im not sure who you may be on the phone and I wont be able to organise and allocate the stock properly.
My preference is to deliver items than to have them picked up as I do not have the time. I may be able to offer a time window where people can come down and pick the goods up. Delivery to Melbourne Metro via couriers please is from $15 for up to 25kg. Considering the fuel cost and time - delivery works out to be nearly break even or cheaper in some cases.
Door Scuff plates - $55
Passenger Seatbelt Buckle - the one next to the console - $35
Window glass, switches and regulators have been withdrawn from sale due to lexan/plexiglass costing too much and not worth the the money for the weight save / inconvenience.
I'll update this thread shortly.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
