hi all me again asking yet more questions :uh-huh:
in my everlasting triumph to convince my dad to buy a skyline over a new 2003 model crappy car i have come across an effective way to argue my case.
i can argue how RWD is sooo much better than FWD accept before i do that id actually need to know why. basically i know theres better control and traction but is this only at higher speeds? If you could please write basically the facts of the advantages of RWD over FWD id really appreciate that thanks
No flamers unless u have to :D all bumps welcome :bahaha:
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/
  • Replies 47
Bambam's right, FWD is safer to control....in other words...it's harder to get it 'out of control'
definately less prone to spinning out in the wet.
advantages of RWD in the real world? Not much...
That's only if you wanna put your case forward that it corners and handles the way a car should on the race track.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546750
becoz it is a lot more fun
fun=danger
theres better control but not traction
unless u can use yr accleration to turn a corner, let yr tail go out a bit, but can u??
go for 2003 crappy car. u are just a kid, u should learn what a car has to do.:P
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546760
here's something to read about....not sure how relevent it is in your situation.
Article on FWD vs. RWD vs. AWD
http://www.toymods.org.au/fwd_rwd_awd.html
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546780
my first car was fwd, and guyz at work teased me cauz my engine faced the wrong way ! wen i got into my the skyline, its a different feeling altogether, missed the fwd in the beginning but after having a few exciting moments ;-) i wudnt go back. plus engine faces the right way now.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546848
Things worth trying might be: (dunno how true these are, but if he dosn't know cars might be able to pull it off).
- The fact that there is a driveshaft running down the lenght of the car makes it the chassis stronger and more solid in the event of a crash.
- The only reason front wheel drive cars are made, is because their cheaper
- Skyline brakes are generally very strong (not related to drive but might help).
- If you know how to drive properly (which u obviosly do:)), RWD cars can be easier to controll, understeer badly in a corner in a fwd car, ur stuffed, oversteer can be controlled to an extent.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546868
Drive any car stupidly and you can get into trouble. FWD is definitely a safer drivetrain. RWD is more fun, but basically I think you should follow everyone's advice, stop trying to bullshit your old man and buy a car you want with your own money.
If your old man wants a boring, reliable, economical, cheap to insure FWD car then try and bend him a bit but a skyline would be totally inappropriate for his needs.
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546873
RWD : Weight distribution is more balanced than FWD. Braking performance is enhanced. Your tires will wear more evenly.
Cornering is easyer and more responsive. Hard acceleration performance is better than a FWD.
Cornering is better due to power and steering is aplied through separate axles instead of the one. There is no torque steer.
FWD : traction is good during mild acceleration on wet/slippery surfaces. Lighter than a RWD. Better fuel economy. Most FWDs have a small engine. Interior room is enhanced because of no longitudinal driveshaft. Cheaper to afford
If your still after that r34 ive left a link in the other r34 post.
Hope i could help
Skyline boy
https://www.sau.com.au/forums/topic/25752-fwd-vs-rwd/#findComment-546883
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
