On my way back to the office yesterday on Chesterville rd, there was just 2 cops random breath test. I pass the breath test but the cop decided to ask me to pop the bonnet I got done for having a BOV later he also decided to fine me with the exhaust without even testing to see if it is over the legal limit. Are they allowed to fine you for this? without asking you to go and get it tested?
https://www.sau.com.au/forums/topic/257525-defect/
he can defect you, however he can only suspect that your exhaust is too loud, and can issue you with an epa notice, however as far as i know, he is unable to actually fine you for the exhaust... are you sure you didn't recieve the fine for the defect (bov)
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431662
That's Victorian law.
They can just report you willy nilly without proof, evidence or otherwise.
If your exhaust is legal (when you get it tested) IMO lodge a freedom of information request to the EPA, get the officers name, number and so on and take him to court.
They law really needs to be changed so that they cannot report people without fact.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431696
Thats why I hate aftermarket BOV, they are pointless and just give noise and you already have the stock one.
I remember you car is pretty stock except for the FMIC, Boost controller and Exhaust, so you probley won't have to do so much work to get it cleared.
I suggest you put your stock cat back exhaust on and get the defect cleared.
Wait about a week or 2 then if you get a EPA notice you gota take your car to the EPA so they can test your car is quiet / meets the correct db levels.
In which I strongly advise you to remove the BOV and keep your stock exhaust on!
All the best!
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431832
Well guys i failed the test it around 100db @ 5k rpm. The guy said he couldn't give me a epa cert, since i've dont have a epa letter. So i need to borrow a stock r33 s2 muffler if anyone has one that i can borrow for a week or so i would appreciated.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4431930
you wouild need an epa notice to get it filled out to actually clear the defect if im not mistaken. i think vic roads sites it in order to remove the defect. I'd say you may be getting one in the mail some time soon.
100db is mega loud considering you just replaced your muffler. I got 96 with 3" turbo back with hi flow cat on my dual exhaust. I can reccomend a listed tester once you fit the stocker back on.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432140
lol 100db @ 4700 (4700 is the test point from memory)... thats fairly loud so i can see why the officer will dob you in.
You didnt get a on the spot notice did you?
Because you'll be getting one in the mail (EPA letter) and THATS when you go get it tested.
You might as well take this opportunity to put a stock or GTR BOV on (i have some for sale :wave:)
And also get the exhaust back to a more reasonable level to avoid such attention again
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432156
i got one you can borrow.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432367
If its the same as my defect you can drive the car as much as you like untill the 25th and after that date you can only drive it to a repairer or vic roads for another 21 days then the rego gets suspended.
Also is it a major or minor defect, will say on the defect notice, if the exhaust is on the defect notice then you have to get it fixed before the defect can be cleared, go to who ever your going to get an rwc through (assuming its a major) and see what they want you to do.
The fine will most likely be for driving and unroadworthy vehicle.
https://www.sau.com.au/forums/topic/257525-defect/#findComment-4432625
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
    • Won't get near 400kw, pump and injectors nowhere big enough. Bin the manifold and get off the shelf and a modern ECU.
