cool thanks for clarifying. its a minor defect..
Anyone go a stock r33 s2 exhaust i can borrow?
Maybe it might be better to get your exhaust fixed, for such minor mods you dont need such a free flowing exhaust, all its going to do is get you another defect, next time it will probably be a full rwc, you got off easy this time.
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4432944
Hey guys, am a bit confused what to do here, most of the stuff are back to stock the only thing is my muffler still looking for a stock muffler. I check on vicroad web site and this is what they state; I have not recived a letter from the EPA and i dont have a defect sticker on my windscreen??
How do I clear a Victorian defect notice?
The defect notice will specify what you need to do to clear the defect notice. One of three types of requirement will be stated on the notice:
  • Self Clearance - You are responsible for repairing defects mentioned in the defect notice and you must sign Section 8 of the Defect Notice once the defects have been repaired. You will also need to forward the "blue" copy of the Defect Notice to VicRoads.
  • Clearance by VicRoads - You do not need to obtain a Certificate of Roadworthiness. However, you must present the vehicle for inspection to a VicRoads Customer Service Centre to ensure that the defects are rectified and the Defect Notice is removed. No appointment is necessary.
  • Certificate of Roadworthiness must be obtained - You must present a Certificate of Roadworthiness obtained in respect of the vehicle, dated after the date of issue of the Defect Notice, at a VicRoads office. You must not remove the defect label. If the label is present, the vehicle must be presented at a VicRoads Customer Service Centre for removal. If the label is not present, ie where the windscreen was replaced or where a label was not attached, the vehicle does not have to be presented.
Defect notices issued by the EPA cannot be removed by VicRoads. The defect notice will state where to go to get the defect notice removed.
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4444169
If you have not recived a letter from the EPA then your fine and Thank god you didn't get one either cuz they are ahead f**k.
To clear the defect you have to do all the mods on what the notice has told you to do and take it to a VIC Roads centre, there is usually like a 'drive in' where you park your car, swtich it off and wait for a VIC Roads officer to come out or you go in and ask an officer to come out.
Give them the notice, let them read it through and let them see that you have done the changes.
If you pass they will tell you and remove the defect.
Your free to go!
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4444418
How about this part on Vicroads website
I dont have a defect sticker do i still need to take my car in for inspection?
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4444637
Sounds like the pig gave you a half ass defect...
So he didn't give you a yellow sticker, but he wants you to goto a mechanic to get a RWC (Road Worthy Certificate) then present it to VIC Roads saying your car is fine.
Get a RWC done from your mechanic, take it to a VIC Roads Centre, explain to them the situation when you got pulled over and present the RWC and the write up from what the pig gave you to tell you want needed to be changed and see how you go.
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4444662
Cool thanks for clarifying, my next question is; when i go and get a RWC do they need to do a full standard inspection? like tyres, windscreen wipers etc or do i just tell them about the defect get them to check it and write it on the certificate? I got quote $100 bucks for it
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4444728
Depending on the write up on what the cop gave you...
Was is a major or minor RWC needed?
You only go according to the write up cuz there is no need to fix anything else unless stated on the write up sheet.
In your defence, only give whats needed, cop tells you to fix this, then only fix that, nothing else otherwise you be wasting your time.
Major = Full Inspection, Minor = Standard Inspection, or whatever the system is... Your mechanic will know what to do if its a Full or standard Inspection.
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4444758
on the defect sheet the minor box is tick.. Cheers for that, at least now i know what to say to the mechanic, coz when i went to the mechanic the first time to get a quote he said that we needed to to this, that and everything..
Cheers mate.
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4444815
They are simple to take off.
Wet a rag, warm water, hold it to sticker for 5-10mins re-soaking the rag every few mins
Thing should peel off.
Or just take it off soon as the cop drives away, and then stick it on with sticky tape... that isnt legal though... as technically your removing it, but then if its still there then perhaps not as its still "there" :down:
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4445572
I went with that option, but it is still in my glove box.
https://www.sau.com.au/forums/topic/257525-defect/page/2/#findComment-4445577
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
