Jay019's Thread Of Drift Photos And Other Randomness
  • Replies 84
Drift Practice - February 2009
Click images for larger versions...
More at http://jay019.com/photography/driftprac_2009-02-14/
Edited by Jay019
1,7,11,12,13 would be my fave's
When setting yourself up for a day of taking pics u should look at the angles of which the car is coming in at.. these pics are the right angles... rear end shots are good but front shots look better in my opinion!
Yeah true, front shots do look awesome, but I also wanted a bit of variety otherwise id have a couple hundred shots that all look the same.
Next practice i'll be heading off to the first S's for some shots there as well as some more experimental shots like the very last one.
Hey, some great shots there, i don't usually do public drift days but i intend on going to the next one! What camera are you using? i think you got the frame set up the way it should but just need to bring down the shutter speed so you get the perception of motion in the rims, Having such a high shutter speed give's frozen rims that just look strange when you know in your head that the car is doing some speed but it looks as if it is still in the photo
  • 3 weeks later...
Cheers. I used a Nikon D40 for these shots, but just recently upgraded to a D90.
I definately do need to learn to slow the shutter speed down. My panning skills are not that great but its something that I'll keep trying to get right over the coming year as I plan on being at every drift event at Mallala. Its definately a new skill im trying to learn as I come from an "abstract art" type of background and am still fairly new to photography.
Let me know when your next going up, I have never actually done drift days and want to give it a go, i mainly do privet days, I am not a pro at this by any means!! I shoot with a D80 but very soon a D300 I hope! here are 4 shots from my trip in january that show panning, give a good perception of speed.
  • 5 months later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
