Mammoth Parts Sale
Please if i haven't listed something that you need please ask, good chance i have it
RB25 Alternator $150
RB25/26 Starter Motor $100
RB25 A/c pump and condenser $150 for the lot
RB25 Power Steering pump $100
RB25 series 1 (different to series 2) ABS system $200
RB25/26 wiring loom (series 1 dash loom to 26 engine loom) $200
R33 GTR Centre guages (carbon trim Front torque, boost and oil temp) $250 Good upgrade for 32 GTR's
Space Saver $50 suit all Nissan Imports $50
Standard R33 GTR Parcel Shelf $50
Complete set of R33 Seat Belts including a lap sash belt for rear so it would make it a 5seater $200 complete
R33 Sunroof glass with switches and electrics $400 for the lot
33 GTST Standard suspension no leaks $200
2x Standard r33 GTST suspension no leaks $80
Standard R33 GTST Swaybars $50ea
Tail Lights $100ea
Headlights $120ea
Standard R33 rear bar $100
R33 doors incl door trims $200ea
R33 Series 1 bonnet $150
Boot lid $100
Standard R33 Series 2 wing $75
Trust Front Bumper needs Fiberglass to fix crack on lower lip $100
Front windscreen glass $80
Rear Windscreen $150
Rear 3/4 windows $175ea
M Sports Rear Bar perfect condition $200
32GTR Front diff good condition $150
R33 GTST Front guards $100ea
Standard R33 Instrument Cluster $100
Complete Dash $200 (includes centre console)
Rear 3/4 trims $100
Floor Carpet $50
Headliner will only suit R33 equiped with sunroof $80
Standard Series 1 passenger seat $80
Standard Castor rods, toe arms and camber arms $50pair
Walbro 500hp fuel pump $60
Standard R33 GTR Exhaust, good upgrade for GTST $250
Standard R33 GTR Front Pipes $80
RB26 Modified Sump Suit RWD $400
No doubt i have more crap that i haven't thought of
All prices negotiable to an extent but no stupid offers that i will no doubt still get
Need to offload all of this and finally get rid of this car
Contact me by mobile would be the best 0404585529
or you can PM
Cheers Marty
Edited by Weapon
  • 1 month later...
<br />Please if i haven't listed something that you need please ask, good chance i have it<br /><br /><br />RB25 Alternator $150<br />RB25/26 Starter Motor $100<br />RB25 A/c pump and condenser $150 for the lot<br />RB25 Power Steering pump $100 <br />RB25 series 1 (different to series 2) ABS system $200<br />RB25/26 wiring loom (series 1 dash loom to 26 engine loom) $200<br /><br />R33 GTR Centre guages (carbon trim Front torque, boost and oil temp) $250 Good upgrade for 32 GTR's<br />Space Saver $50 suit all Nissan Imports $50<br />Standard R33 GTR Parcel Shelf $50<br />Complete set of R33 Seat Belts including a lap sash belt for rear so it would make it a 5seater $200 complete<br />R33 Sunroof glass with switches and electrics $400 for the lot<br />33 GTST Standard suspension no leaks $200<br />2x Standard r33 GTST suspension no leaks $80<br />Standard R33 GTST Swaybars $50ea<br />Tail Lights $100ea<br />Headlights $120ea<br />Standard R33 rear bar $100<br />R33 doors incl door trims $200ea<br />R33 Series 1 bonnet $150<br />Boot lid $100<br />Standard R33 Series 2 wing $75<br />Trust Front Bumper needs Fiberglass to fix crack on lower lip $100<br />Front windscreen glass $80<br />Rear Windscreen $150<br />Rear 3/4 windows $175ea<br />M Sports Rear Bar perfect condition $200<br />32GTR Front diff good condition $150<br />R33 GTST Front guards $100ea<br />Standard R33 Instrument Cluster $100<br />Complete Dash $200 (includes centre console)<br />Rear 3/4 trims $100<br />Floor Carpet $50<br />Headliner will only suit R33 equiped with sunroof $80<br />Standard Series 1 passenger seat $80<br />Standard Castor rods, toe arms and camber arms $50pair<br />Walbro 500hp fuel pump $60<br />Standard R33 GTR Exhaust, good upgrade for GTST $250<br />Standard R33 GTR Front Pipes $80<br />RB26 Modified Sump Suit RWD $400<br /><br />No doubt i have more crap that i haven't thought of<br /><br />All prices negotiable to an extent but no stupid offers that i will no doubt still get<br />Need to offload all of this and finally get rid of this car<br /><br />Contact me by mobile would be the best0404585529<br /><br />or you can PM<br /><br />Cheers Marty<br />
<br /><br /><br />
Got a rear sway bar? Im in Melb
  • 3 months later...
  • 5 weeks later...
 Share
    • Big claims here.  Any links up on the website ?
    • If your HP goal is reasonable and you are not drifting. Buy a new R34 box.  If the above is not true, buy a wrecked R33 box and put a gearset in it.  CD09 are not as strong as you think and the cost of / mess around of the conversion puts you in gearset territory.    Also the deal above is awesome,, get that
    • Just got back from a little hands-on with a G58 Baron....I was thinking about this... ..best I can figure it, that pinny was tail-ended ...I didn't really think about the wiring, because all that mattered was the tank and pump cradle (I think I mentioned the pump itself I couldn't vouch for)...which didn't matter, as you said you'd be replacing the pump anyway.... ...'for some reason'....and I imagine this is the panel shop's doing... they've replaced the cradle wiring with a metre of 7-core trailer loom, and attached the loom plug (from a different car) to that. The actual cable run from the top of the pump cradle, to fuel pump harness end in boot, is maybe 60cm in length...so I've no idea why they did this... ....the connector in the boot of the pinny, is not going to help you here...because in theory, it should still be present on your car. On top of that, because they've done what they did, we have no idea which colours of the trailer cabling, have been connected to what on the fuel pump cradle (pump +/- , shield, fuel guage/low-level senders)... ...this means, best approach is to remove the pump cradle, and re-work it now ...not later. That is, if you were going to replace the pump, do it, replace the soft lines at the same time...and sort the wiring out (replace that trailer cable with the wiring loom off your old cradle)...
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
