300c touring srt 8 is the only way to go ... when it comes to the 300c range. :)
very nice car to drive around in...
got one sitting in my garage hehe :(
i dont have much respect for the sedans.. esp the 6 cyn ones. And have poeple who have number plates like "bigspenda" when the 300c base model is only 50k.
I think people see them as "bentlys" but alot cheaper. Hence buy them. then drive around like their big shots.
lol. :S
6.1 hemmi of a 300c is awesome, only draw back is its weight but the brakes are adequate and suspension isnt as sloppy as i thought it would have been. I'd rather spend the money on a v8 300c instead of its main australian rival the Statesman which costs more than the 300 and it drives like it should.... an old mans fart.
there is really nothing we can get in Aus that is like the 300c and definately not for value for money. If you want something that goes decent and can take to the track, get a jap import,,,,, if you want luxury, scare 4wd's on the road and you like to be in comfort while you drive on the highway, i'd definately get the 300c.... fuel cost aside lol
Actually now that i think about it only cars that are as big as it and perform similar are the bigger saloon style merceedes, 7 series bmw's, audi a8's, the 4dr bentley sports things..... mind you all of these cars start at around $200 000 for the basic models.... where as the 6.1 hemmi 300c top of the range is under $80k, also you can squeez them down coz their desperate...
Also i think the 300c is a good car and surprised me is because its not an american car at all.... its made in Austria!!!! so thats why i loved every second of it...
still i rather my skyline lol but if i was offered one at half price i'd definately find the money for the 6.1L 300c.
My good mate had a black 300C on 22's and i loved it to death, was one of the first ones in north queensland, the attention the car got was unbelievable. However i think this new model has "softened" it's looks a bit too much, making it to round.
Maybe in real life it will look good, we'll see...
Agreed SRT 8 is the only way to go! The tourer doesn't look too bad for a station wagon either. It's no Stag though :)
Agreed.
Chrysler have always had the happy knack of taking a turd and covering it with icing. Its still a turd under the sugar.
The old adage still holds true. If you cant afford a ford dodge a dodge and rev a chev.
f*k, they just made the shittest car even shitter! When the CEO has admitted to saying that they are behind their competitors you'd have to be on crack to waist your hard earned on a yank tank shitter like one of them.
I pity the driver of each one I see.
Edited by r32line
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
