  • Replies 2k
Hey guys, I thought I'd add to this thread...
I've personally driven benny's purple DR30 beast many times and can vouch for the performance, FJs are awesome!! On 0.9bar It pulls harder then.......
*ahem* well, lets just say it pulls bloody hard! It'll be even better once he shuts that damned diff up!! (sounds like its about to spit out the crown gear!:) )
It looks even better in the flesh too, the depth of the purple is hard to capture on camera.
Twice as fast as your old R32 benny? Perhaps...Is it twice as fast as mine though? Naaahh!! Quicker definitely, but we shall see! :(
cya!
benny- thats sweet mate, very peeved though, looks like you've got the rims i have, well 3 and a half of anyway, thats the anoying thing they look brillant fit under the gards so well, can't find a replacement anywhere and they carnt be fixed!! looks brillant though the colour is great, makes me think of changing mine from the red and black to one colour!
does the link in post 156 work as it works for me??
two very nice examples of old school skyline style, byring a teer to my eye seeing them!!
hey guys thanks for the feedback!
Boof: not sure about the injectors, but i can't run it over about 1.0 bar boost, so the injectors are probly at their limit. Also i was told the afm on the fj's are extremely restrictive so engine management with map sensor, definately the way to go!
rsx84, are your rims SSR's? mine say ssr on the valve caps. btw the linked workd fine for me.
Any of u import 2door guys have any trouble getting ur cars to meet adr's and rwc's etc?
btw, the rear quarter windows in my car can be wound down!?.thought that was cool hehe
benny- no dude mine are Hayashi racing multi spoke, may be just a simaliar style then, you've still got four of them though!! have looked at r30 club web site at the half cages and centre floor bars, with the fifteen year rule not to many hassels, but half of us are looking at or finishing rb20 transplants.did you import it or buy it over here, looks very much like full import to me!
rsx84- apart from the fmic and turbo back 3 inch exhaust, it has a Trust oil cooler, boost relief valve, hks pod filter, greddy profec ebc and the guys at the workshop think it might have a have a high flowed turbo.
Also the dash is cluttered with 5 aftermarket guages, shift light and a speed meter.
btw, u had your car dynoed?..any mods to the rb?
benny-nice, sounds like money well spent, are there any other things out of the ordinary, you know brakes, suspention and fuel system it would be nice to know if the japanese boys know any little tricks to the r30??
DR30RS-nice run what came second? yet another person with similar rims!! oh well you lucky bastards..
i was thinking on what info we lost and through most of it was on brakes and struts so if you have any throughs or have done something alone these lines post it as it all helps someone!!
Cheers
yeah have a look at this thread as there are all the old brochures, slightly cheaper!!
http://www.skylinesaustralia.com/forums/sh...ight=school+r31
you can go into each brochure and see each page, it seems to be mostly in japanese though!
rsx84- as far as i know, the brakes are standard...it has lowered springs all round with what looks like standard front shocks, this makes the front end mega stiff...also has cusco adjustable strut tops....the rear shocks are bilsteins, which makes the rear end a little more aussie road friendly hehe
DR30RS- nice figure!...ur fj been rebuilt?....what turbo are u using if u don't mind me asking?
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
