MR & DR front callipers are NOT interchangeable, they are different mount centres and the DR calliper is bigger and has to go around a disc rotor over 20 mm larger in dia. and 4 mm thicker
ah yeh, i was thinkin HR30, i had to interchange calipers from MR30 to HR30 and they work fine, so no mounting differences there :thumbsup:
  • Replies 2k
how convenient, im looking for one at the moment. hows the condition on that
sucker? and what you askin?
crimmo: try InjectMaz for wiring. i know he's done a 30 to rb20 before and he can often beat or match prices but the best thing, he can come to you if you ask nice. pretty cheap for cash too...
also, im still in the dark with these calipers... should i get em and try, i mean if they dont fit, they can be made to fit without too much hassle, so it wont be a total waste? oh yeah, crimmo, what discs you using at the back?
anyone know the size of dr30 rear discs, the DBA thing lists something like 258 but apparaently thats wrong...
I got marky mark from exhaust technology to make me up a bend off the front housing of the turbo for a carton.
With my wiring ive booked the car into fours'n'more to be wired up in a week or 2, for about $500, could injectMaz do a better price/job?
I pm'd about the brakes :thumbsup:
Typical. I search for R30 information everywhere on the net for a year, nothing....
Get rid of my car finaly and what happens? One of the biggest threads on this site dedicated to R30 Skylines...
Bah....
would anyone have a spare HR / DR steering wheel?
mines rogered
Any stocl R30 steering wheel is the same, with the exception of the horn button pad. The DR/HR has a bigger thicker pad.
I have the thicker pad, as you would as well and might know where there is a good wheel, will get back to you if I locate one.
The N12 Pulsar EXA Turbo Wheels is also the same, just have to change the hubs.
Hey i just bought some tail lights from RSX 84 and when i got them (like he said) they have some rust crudd in the indicators and reverse lights. I tried to pull them apart and pretty much got every screw and nut off but i couldn't get the perspex and plastic to separate, i didn't want to use force in fear of breaking them so i ended up cleaning them from the back of the globe. i spent half a day cleaning the bastards with all different things (even my dremel with a flexable joint and soft brush on the end) but nothing can get right up in the corners!
Is there a special little trick or some hidden clip that i need to take off to get them apart?
exhaust question..???
im getting a new exhaust for my r30 but want to know what size u guys have and if theres a size too loud or bogan on these cars..
my mates rex has a 3.1/4 inch and it sounds good but i think that would sound different(too loud) on a 6cyl??? im thinking of going for something closer to 2and 3/4inch
also extractors... are they worth the extra $$for the economy and power..
PHat MR30,
The rear tail lights are glued together, the clear over cover is glued to the base etc. As far as I am aware, they don't come apart, or at least aren't designed to. Maybe if you try breaking the bond around the sides you might get to the lenses, but would have to be careful not to break them, but then you need to be able to reseal them again.
nicko,
Is your R30 stock or a hottie?
If stock L24E, extractors and about 2.5 system should be cool, 2.75 if using normal bending processes, if mandrel, 2.5 is plenty.
Be advised though, either wrap the extracters or get them coated before installation, because heat in the engine bay is a recipe for disaster when chasing any power increase.
My HR30 will have 300/400 HP at the wheels and my system is 3 inch from the cat to 1st muffler, then 3.5 back to a twin 3 inch outlet, 3.5 inch inlet muffler.
Reason: As the exhaust gases cool, they expand, so the system has to increase diameter as it gets closer to the rear, to ensure the same flow rate as it leaves the engine pipes.
Also, to big! will take power away.
nicko, besides mine i know of 2 others with zorst round town, i bought 1 with a side pipe exiting just behind the front wheel, sounds like a top fuel drag car, doesn't go like one. i only bought that one for parts though, engine will go. and a good mate (who introduced me to R30's) went to carline in margaret st launceston and had a 2 1/2" press bend, with a resonator, and muffler at rear with a 3 1/2" tip on the LEFT hand side of car (cut the outlet out). This sounds absolutly sweet and pops flames.
Or go mine 2 1/2" mandrel bent, but chopped the manifold and joined 2 1/2" onto that, then resonator, and muffler at rear 4" droopy tip. doesn't sound quite as sweet but sounds like it has more HP, could just be cos of increased capacity.
yeh i tried breaking the seal but no go, too close to cracking the plastic. will just keep at them are getting better the more i do.
as for ebay i could never find any thing dr30 related on there so i haven't really looked lately, much else?
oh and ghost rider have you been getting my emails?
phat i was going to try exit mold, let it sit in there for a few hours them drain it and a wipe down but never got around to it! also i just look at the ebay konis 3days to go and i found them by just doing a skyline search second or thrid page? $142.50 is the current bid.there are also a set of the same taillights as the ones i sold you for $30 (they have a large crack/hole in them)
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
