well when i mounted my vg30 i had to 'tweak' the oil line , cant remember which one cause it was hitting something.
as for the tacho yeah i read somewhere (very specific arent i) that u need to put a resistor in somewhere to alter the signal
may have been PF...."how to recalibrate r31 speedo" :P or sumthin
  • Replies 2k
get this, i posted ages ago about my diff and what the diff was doing??? after a week of f#$king around with it, i find out its the hand brake thats the problem, the passenger side cable has been crushed and when you put it on it stays on so while driving i've had the rear brake on, doh, so now she goes alot harder!!
a mate at work told me about the need for speed forum the other day as someone there has created a dr30 to race in the pc version but found this as well. onyone know the side skirts at all?
The body kit is from JENESIS, www.r30.co.jp the front bar is identical to the one I have here in OZ that I plan to make in small numbers. The side skirts cost an arm and a leg to get here to OZ, so that moulds could be made to reproduce them locally.
The rear view car has the STOCK DR30 body kit, found on most RS-X models, same as the Peter Jackson cars had in the late 80's.
I am making enquiries on how to get them, or maybe modifying R31 or R32 ones to fit, so that I could market a complete body kit for R30 Skylines, strictly on a limited basis, after all, we don't want them all the same. :ghost:
RSX,
They look a little different to the JENESIS skirts.
Do you remember where you found the pic?
If so! email him/the site and ask some questions, or PM me the site and I will do the chasing for you. :ghost:
ALL R30 Parts are interchangeable. The DR struts bolt in, same lower ball joint & control arm, guards, bonnets, etc, everythings the same, that's why we are chasing them.
The only changes are coupe doors don't fit on sedans, unless you want to cut them in half, but if it comes off a coupe, HR, or DR, it don't matter, if it's sedan, fits another sedan. etc, etc, etc.
hey guys, im thinking of putting together a 30's page? what you reckon worth it or not?
i mean i am going to set up a page for my car regardless, but then i was thinking there is no definitive r30 info resource....
if you guysthink it'll work, let me know and i'll start getting info etc
cheers
cheers
are you talking on this site (photo gallery) or outside, as a few sites have been started but theres no great sorce of info out there but if you have the time to go back through this thread you may be able to get some great mod info!! i'd also be up for starting a photo gallery here through get us all somewhere to put pics!!
cheers
Well if your doing one up for your 'line, you might as well do up a r30 site, as there are very limited english sites dedicated to the mighty r30's, particularly ones with useful info..
Quick note though didnt we lose a lot on this forum due to some computer glitch. As if i remember it was quite useful.
Good luck
Good luck
mostly suspension stuff but there seems to be even better info on this here now! if you do a google aus search you can get a few sites but most are for sale sites or small write up in larger stories, any info i've found is years old and has'nt been updated in the last few years at least!!
http://www.jaustech.com.au/general.htm
http://homepages.tig.com.au/~robs/kevspage.htm
these are the only sites in english that i got any info from, the rest are japanese and when translated make even less sence!!!
Robs/Kevs page is fairly informative and Rob's car is still under development. And the site will probably be upgraded when it goes back on the road again, but he hasn't done the brake conversion we have on this site, he hasn't done the body conversions, or suspension, mostly his mods are of standard available parts as opposed to Jap import TRICK BITS.
AND >>>>> SIDE SKIRTS >>>>> Might have the Jenesis ones here in a few months, so we can see what I can organise for copies.
RSX,
Your Avatar, IS IT YOUR CAR????
RSX,
yeah its my car, pics taken around three months ago in the parking area of my units!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
