I'm going to have the same problem, as my R33 gearbox mount is about 150mm further back than standard.
I am making a "C" type mount that carries the original g/box mount on a box section piece of RHS having about 4 mm plates going back to the original mount points braced with a web section fillet.
Just have to get under it and design it, put it on paper and get someone, any welding/pressure vessel shop to make it for you. About any Sheet Metal/Engineering Shop will be able to point you in the right direction if they can't do it themselves.
ok, cheers for that mate, ill let you know what i come with :D
i also thought about dropping bolts through the floor so the mount lines up with the xmember... ?
  • Replies 2k
If you do that, make sure the holes are reinforced, because with continual driving and some hard launching, they will tear out of the floor, making a bigger problem than the initial one you have now.
Might be better to use the orig and mount back to them
ANYTHING will fit if you try hard enough.
I put my SAAS seats, on a piece of 12mm aircraft grade aluminium sheat and then mounted the runners to the same sheet, that way I still had some adjustment front to rear.
I removed the height adjustment as I needed to lower the seating position about 100mm to allow me to sit in the car with a helmet on.
I am going to experiment with R31 seat tracks, as the height adjustment is on the track and not in the seat.
I have a set (pair) of Z32 import seats if anyones interested, they have a fully electric drivers seat. forward & aft, height, lumbar, and wings. Would have to make up mpunts as they are a very narrow seat.
Mike,
Do you presently have DR30 rear brakes?????
If yes! they are identical to Z31 300ZX rear rotors.
If you don't want to buy NEW, find ANY wrecker that has Z31's.
Are the rear z31 calipers similar to DR30?
Mike Cash - how did you go getting through regency?? or have you got any more info on what you would need to do?
ghostrider: im assuming that z31 rear dics would be the import old rb20 z31 or the aussie one, or are they the same size?
nah i got the dr30 rear end on mine at the moment and my dics are undersized from ever use.
as far as regency goes, aparently all you need is the same dics size as a car that had an rb20det. in my case i used r31gts fronts and dr30's rear and other cars have been passed without any engineering certificate or anything.
Will S13 seats fit - i got a set for free.
Measure the rail spacing. I measured a set up for my R31 (which may or may not be closer in design) and the S13 rails were about 45mm too far apart - the R31 centre to centre of the rails was 415mm where the S13 was about 460mm.
What or how do you call an DR30 HEAVY???? What are you comparing it to???? Maybe compared to a Mini, but to another Skyline, it's one of the lightest. DR's max weight 1250Kg, R31's OZZY sedans 1600Kg, HR31 coupes 1350Kg. How you say heavy????
WHOA! where'd you get that weight from for the aussie R31!?!?! I weighed mine with 40l of fuel, spare, tools, jack, assorted crap and full trim and it was 1280kg on an extremely accurate weighbridge. Mine is a "stripper" model GX though, with no luxo bar power steer and aircon, with basic trim, and its manual.
All reports I've heard peg the HR31 at closer to 1400kg, on the + side....Especially for the sloppy fat bitch Passage's...
my epic adventure is comming to a close, pick up the rims with new tryes tomorrow morning went for falkens ze512's 225/50 on the rear and 205/55 on the front, pick up the front seat, new tacho and boost gauge on sat then its fix the lights and shes ready for engineering!!
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
