r30 skylines
rsx84
 Share
got the piping done, was very happy with the end result, they even moved the pod filter to a better spot to take full avantage of the larger whole for the pipes in the wheel arch!
its a mix of mild steel and alumimun, mostly 2.5" with a bit of 3" for the afm and pod filter!!
  • Replies 2k
Crimmo: was specking to ghostrider and he said you are looking to get a r200 diff, are you looking to get one with the rear dr brakes and calipers attached and use them as i'd be interested in chipping in with you if you didn't need the brakes??
Hi Guys,
We have had an in length discussion on brakes on another post, all the time some getting rather confused and heated at the same time.
We discussed effectiveness on different sizes and set ups, comparitive solutions, best or worst, recommended or not.
Rear brake rotor diameters, better than others etc, etc, etc.
I was all but crucified for my sticking to the fact that our DR30 rears were more than adequate, for almost all conditions. With upgrades like slotted rotors and EBC pad compounds, they would be better than most even under race conditions & chasing through the Brisbane Hills area, my contention being the leaverage of the 290 diameter rotor and the best part, THEY WERE/ARE SIMPLE BOLT ON UPGRADES.
I used to drive an MX73 Cressida & now have an MX83. Bigger, heavier, more powerful etc, etc.
The MX73 had 248 x 22 ventilated fronts & 269 x 18 ventilated rear.
The MX83 has 256 x 22 ventilated fronts & 272 x 10 SOLID rear.
GO FIGURE????????
Hi Guys,
Anyone wishing to convert their STOCK MR30 shifter into a short shifter, let me know.
And it's not making it shorter in length, it's making the throw in the gearbox about 20mm shorter, similar to the Nismo RB short shifter, but the cost is ZERO.
Hi Guys,
That should also work for FJ20,Z18,all L series Dato's,etc.... I'm sure a few people would be interested in the mods. Better get typing! :(
What you going on about??????????????????????
Who's talking G200 Charade, I thought this was an R30 NISSAN SKYLINE POST?????
Am I on the wrong web site or something?????
got my eye on a tomei short shifter kit for the r32 box at the moment, this is for the shifther itself not the travel as i'm goingf into 5th from 2nd far to much!!!
The modification I speak of, is for the STOCK AS A ROCK R30 shift lever, used on L series engines. Not RB conversions, for these the mod is a new shifter @ about $200/300.00
After modification the length of the throw physically shortens by about 20mm.
Does not work or affect R32/33 shift levers. AND
rsx84,
the shifter you are looking at does shorten the stroke/throw by about 20mm also.
Hey, i have an 1984 Paul Newman HR30 and i'm having some problems with my diff. Do the HR's have standard LSD? i bought it off a guy who told me it had an RT200 or something and the other day i was trying to cut some circles in a car park and it just wouldn't light up properly. i took it to my friends place and we put it up on axle stands and only one of the wheels was turning. i've been lead to believe that this means it is an open wheeler... is this correct? If it is standard LSD where can i get one?
Cheers
Yeah Sam, if it spins only one, or spins one one way and the other one the other way, its an open wheeler. Mine spins both the same way, and I've also gone to the trouble of checking that it works properly in real world conditions :lol
I thought HR's had a LSD as standard though.... so maybe yours is just shagged
Actually... having seen Paul driving it before, I know it had a working LSD a year and a bit ago
Cheers
Sam,
If you went back through this post I think you would find referrence to your problem, as I have addressed it before.
The Paul Newman comes standard with a 3.9:1 R200 LSD, the problem is, Nissan used it as a marketing ploy, rather than a performance factor.
Your R200 LSD is working as an open diff, primarily because the preload in the diff is to low, it's stock at 15/20lb which is far to low, hence it's tendancy to only spin one wheel.
You have to take it to a Diff specialist, or I can enquire from my man here in Sydney if there is anywhere in SA that he can recommend, but for street use, the pre load has to come up to about 50lb and for track, 70/80lb.
It's going to cost you about $400/500.00 for this modification.
Hope this helps.
Yeh! Well it seems he has a problem, although it is extremely rare, that an R200 breaks. It is considered after all to be the IRS equivalent to a 9 inch.
The crown & pinion can go, but not usually the LSD centre.
And L20ET is rated at 108Kw (145hp) engine power.
And the Paul Newman definitely doesnt have the 200hp some people have been quoting, its much nearer the 145 of the standard L20ET
that would have been me talking adout my mates and that figure is ture for his and is also at the fly as stated?? something for you to think about ha!!
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
