  • Replies 2k
Ok,no one discuss it with me then! :goddam:
:cheers:
Adam,I'm going to try some of that Redline Shockproof in my gearbox and diff next change...
As for the front: After much deliberation, if the new air dam is to be used, the tekamon front is the go, but if staying basically stock, I think the tekamon bonnet would look best with modified stock grille and stock headlights.
For Oil: I use 75W/90 Mobil full synthetic in both LSD & Gearbox
YES
I agree with you :D
Hmmm... 75/90... cool
I swear my diff isnt standard... on the way to a friends place in the hills last night, going up a set of very sharp hairpins on a slope, was in second, lowish revs, once I turn the front wheels a certain amount the diff sort of locks and the inside wheel chirps. I've noticed it when I've done sharp rolling u turns (little or no power on) and its chirped then too
Is that normal?
The car came from Japan with a few bits like the Watanabes, adjustable suspension, 3 inch exhaust, momo wheel, Jenesis (I think) front bar with offset plate and a huge GT wing
My car also chirps in 2nd gear quite easy.....maybe all R200 diffs are like it???
Redline oil is the way to go, it does wonders for notchy as hell toyota boxes, I'm bout to try some in my car...... I'll let you know how it goes!
Does anyone else get this problem on a semi-standard FJ20 box....... for example, coming to a red light, shift out of gear into neutral and coast up to the lights, when it comes time to go again, 1st is a mofo to engage!!! Anyone had similar problems or know what it is???
The engagement problem can be said for many makes and models as ease of selection depends entirely on the alignment of the gears at the stationary position. If it doesn't go into first easy, take second, then first and it should go in easy, second time around.
with my front i have a relativly large cooler sitting infront of the radiator, the 2 slits at the front feed air to the radiator as the fmic sits rather low (for that perposs) i also raised the bonnet using washers about 10-13mm at the hindges to get a little more air flow through the engine bay...
Hey all, has anyone in here modified their Aussie R30?
Im planning on getting extractors and a custom 2 1/2 inch. exhaust made soon.
has anyone done this? if so, how much difference did it make?
I already have a K&N panel filter in a modified air box. Also, does anyone have a manual R30 that they want to sell chaep?
I just want the necicary parts to convert my auto to manual.
and, does anyone have a R30 wagon that they are wrecking? I want the disc brake rear.
And finaly, i want some Jap spec taillights, anyone have any for sale?
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
