  • Replies 2k
Ok,no one discuss it with me then! :goddam:
:cheers:
Adam,I'm going to try some of that Redline Shockproof in my gearbox and diff next change...
As for the front: After much deliberation, if the new air dam is to be used, the tekamon front is the go, but if staying basically stock, I think the tekamon bonnet would look best with modified stock grille and stock headlights.
For Oil: I use 75W/90 Mobil full synthetic in both LSD & Gearbox
YES
I agree with you :D
Hmmm... 75/90... cool
I swear my diff isnt standard... on the way to a friends place in the hills last night, going up a set of very sharp hairpins on a slope, was in second, lowish revs, once I turn the front wheels a certain amount the diff sort of locks and the inside wheel chirps. I've noticed it when I've done sharp rolling u turns (little or no power on) and its chirped then too
Is that normal?
The car came from Japan with a few bits like the Watanabes, adjustable suspension, 3 inch exhaust, momo wheel, Jenesis (I think) front bar with offset plate and a huge GT wing
My car also chirps in 2nd gear quite easy.....maybe all R200 diffs are like it???
Redline oil is the way to go, it does wonders for notchy as hell toyota boxes, I'm bout to try some in my car...... I'll let you know how it goes!
Does anyone else get this problem on a semi-standard FJ20 box....... for example, coming to a red light, shift out of gear into neutral and coast up to the lights, when it comes time to go again, 1st is a mofo to engage!!! Anyone had similar problems or know what it is???
The engagement problem can be said for many makes and models as ease of selection depends entirely on the alignment of the gears at the stationary position. If it doesn't go into first easy, take second, then first and it should go in easy, second time around.
with my front i have a relativly large cooler sitting infront of the radiator, the 2 slits at the front feed air to the radiator as the fmic sits rather low (for that perposs) i also raised the bonnet using washers about 10-13mm at the hindges to get a little more air flow through the engine bay...
Hey all, has anyone in here modified their Aussie R30?
Im planning on getting extractors and a custom 2 1/2 inch. exhaust made soon.
has anyone done this? if so, how much difference did it make?
I already have a K&N panel filter in a modified air box. Also, does anyone have a manual R30 that they want to sell chaep?
I just want the necicary parts to convert my auto to manual.
and, does anyone have a R30 wagon that they are wrecking? I want the disc brake rear.
And finaly, i want some Jap spec taillights, anyone have any for sale?
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
