I got a stock one, but otherwise get it made.
Your sedan got rear discs with it's IRS???
All hatch's have rear discs and they're interchangeable with sedan. Just attach at cross member, but if you do this you will need the handbrake cables as they are different to the drum ones.
nah got me a dr30 rear end. disc, calipers, shafts, everything except diff
  • Replies 2k
r31 gts front shocks etc with discs and calipers
rear is dr shafts (i think) but an r200 open wheeler which has stood the test of time for at least a year of second gearies
Same spec, just different offset on hubs.
Is yours pre or post 83?
82
You would have a TOKIKO style master cylinder???
If yes, there is a 1 inch upgrade available, don't know what vehicle it comes off, but if you took your old 7/8 m/c to a brake shop, or you know exactly what it looks like, get them to order you one.
Our 84/5's can only go up to 15/16 unless we change all the bundy tubing.
im not sure. the cylinder seems to be holding up ok so far. what are the advantages of changing it?
makes sense. z31 discs are the same as dr30's?
Same spec 274 x 22 as your R31 GTS.
We have discussed this topic extensively on another thread.
I have DR front & rear, slotted rotors and EBC green pads up front & black rear.
They are a high temp KEVLAR compound low friction, excellent road set up. But I am going to upgrade my fronts to BNR32 GTR 296 x 32 with 4 spot Nissan alloy calliper, only because I have, potentially over 300Kw at the wheels.
Anyone know if cutting a MR30 hatch grille (the eggcrate one with the three slats) so that the eggcrate crap comes out, effictively makes it the same as the other three slat grilles?
And if a set of coilovers were made for a 180B, they should bolt up to a R30 since R30 stuff bolts up to Dattos?
when i did the engine swap the machanic put the r32 master cylinder on mine, never had a peddel feel so good! with the hr brake callipars on mine i had to go to bendix comp X pads as EBC dont make front pads for these callipars...
Jenesis is www.r30.co.jp but when you access it put it through Alta Vista translation or similar so you can sort of understand what there saying in descriptions.
BUT! don't get to excited, they won't trade with you DIRECT, it's a good site to explore, and a lot of their parts can be made here just from the pictures. It is a good referrence site as well, to see what they do with them in Japan.
If your interested in getting some bits from them, it might be a good idea to put it to open forum discussion and we try and jointly get an order together and then get in touch with a parts importer, like Nengun, one of SAU sponsors.
Only one problem I can see with your car...... far too many doors!
i'd put my hand up for a group order from jenesis as there are a few body parts i'd like from them, i could speck to the boys at option 1 as they have have containers comming over each month...
Already done that, I talk to Nathan & Paul at least once per week.
Yeah i would be interested as well in getting some stuff from jenisis...I know in one of the earlier pages on this mammoth post that there was talk bout it, but that kinda died in the ass i spose...I wouldn't mind some of that bracing for a start that would rock!! Depending on what we can get and for what sorta $$$ it will all cost of course though!!
Geez,you've gotta be on the ball to keep up with this thread!! :D
Talk to Whiteline and they will tell you both rear tower brace and floor braces aren't necessary' date=' but Jenesis makes, sells & uses them, so! someone aint up to speed.QUOTE']
I thought it was still a good idea,even with a rear tower brace,as the mid-section can get a bit "flexy" with no B pillars...
Also,I may be interested in a engine dampener brace from Jenesis,depending on price.Does anyone know if there's something to do the job locally?
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
