You looking at the C-Red one?  Getting that through Regency would be a pain in the arse because a lot of that stuff would have to come off before the numbers check, otherwise they'd send it over the pits
I'll sell you a Tekamon 2 door for 12 :(
What is your takemon 2 door? I want to know more, as i am looking for one now.
Yeah, i was looking at the C-Red one. I think all of their cars come with rego? anyhow, i emailed them asking for info, but they havent written back. Tell me more about your DR, I live in Whyalla, so i would prefer to buy from the same state. As youree in Adelaide, i dont have to travel so far.
  • Replies 2k
It doesnt matter if its registered in WA, SA rego is much stricter, and it will still have to go through Regency for a numbers check, at which point they will spot the big turbo, front mount etc and send you through for a full roadworthy
My car is a RSX Coupe. Not really looking to sell but...
i think we are going to find it terribly hard to put actual images on a t shirt, how about a wire mesh design? i will find a similar pic of an r34 t shirt i have
The wire mesh design is such a good idea, but do you have anyone who can do it? please make sure its not cluttered and has a dr import 2dr (my car type lol).
Any more details on progress?
After discounting some of the suggestions and using PM info, I think this is the go.
As we only have 3 models that are popularly found in Australia, I think it's a cool way to go.
www.skylinesaustralia.com
R30 CLUB
Then the 3 models underneath like Nissansilvia.com.
The 3 models being DR30 Iron Mask 2 Dr Coupes, 4 Dr Standard Front Sedans & Hatch.
How we make the models, doesn't matter at this stage, I just want agreement on a layout, then I can work up some final plans.
Hi Guys,
Any of the SA members that know Crimmo, would you stir him up to send me some pics of his tough looking sedan so that it can be considered for the shirt design.
I also want a clear pic of a stock DR IRON MASK coupe, if someone can oblige.
I don't want this to go on forever, I want to put it to bed as soon as I can so that it can be made, sent to the printers, get screens made etc.
Tah!
well im assuming its off an R31 coz it looks like R31 type lips ive seen on pics of R31s about the internet! kinda like the one off GTS-R's n stuff. like the one that lowers itself as u speed up on 31s, except mine is just a rubber lip and is fixed in place with about 20 screws along the underside!! it came on the car. duno if it is 31 lip or properly meant for 30. looks similar to the 31 ones though. i cant attach a front pic of my car coz its too large :)
Hi Guys,
Tah!
Ummm i've got a couple of pics of it in my front yard just when it went back on the road, prolly not the best though..i'll stir him up in a minute for u if u want..
']well im assuming its off an R31 coz it looks like R31 type lips ive seen on pics of R31s about the internet! kinda like the one off GTS-R's n stuff. like the one that lowers itself as u speed up on 31s, except mine is just a rubber lip and is fixed in place with about 20 screws along the underside!! it came on the car. duno if it is 31 lip or properly meant for 30. looks similar to the 31 ones though. i cant attach a front pic of my car coz its too large :rant:
The R31 lip that lowers itself is on the HR31 GTT and GTX (Are they the right models? or is it GTS and GTX?) Anyhow, the GTS-R has a rubber lower lip, maybe that is what you have on yours?
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
