  • Replies 2k
Josh, you do know that the L Series was around before the L20ET don't you...
Nice pic of Sams car btw
Shane, yeah thats what I want to do, but every time I try to ask people about that they don't know wtf I'm talking about or if its even possible... As I see it, as long as the ECU worked with the standard sensors you'd just need to make a fly lead that went between the standard loom and the new ecu
Hey Josh,
I dont know of any R30's that had a live axel rear end, they were all made in Japan.and L24's have been around since the 60's i think, in 240z and 240c's.
Ohh yeah, you want yours to go better, cut a big hole in the top of your airbox. makes a notable improvement, and sounds totaly nuts....hmmmm.induction noises.
Ohh yeah, can anyone tell me what sort of diff is standard in the MR30 Ti? mine seems to spin both wheels sometimes, but mostly only single spinners. non LSD diffs can still spin both wheels in conditions cant they?
And does anyone know of the Paul Newman for sale at the moment, i saw it in the trading post, and i want to know more about it.
Also, if anyone has a manual MR30 that they re wrecking, i want a manual box, and all the gear necicary for a conversion from auto (Pedal assy. etc.) and a disk brake rear out of a hatch.
Cheers, Mick.
ohh yeah,
Josh, how much of an improvement was the exhaust? Do you still have the dodgy right angle bit at the back?
I m planning on getting exhaust and extractors done soon and want to know how good they are. Do you think it would work if i had the exhaust cross diagonaly accross the car, so it can exit at the cutout, but without the 90 degree bend? If anyone has done this, please let me know
Cheers again, Mick.
another topic: whats the off set for the r30? would it be the same as the r31 as these rims fit the r31 and i want the 17" for the r30...
The standard R30 Ti alloy rim was 15 x 6 & +25 offset
My Monza rims are 16 x 8 & +38 offset
So I would assume the 17's are x 7 and so long as the offset is +38 or less all should be cool.
Having said that, there are a lot of R30's getting around with R31 Silhouette rims on them.
yeah hi everybody i just put this new site on the net all about r30's it was a school project so yeah..... not all facts are correct but check it out and email me if u have any information i can add or comments on the site.
www.mr30.tk
thanks Josh
Sorry Josh, but your site is full of holes.
Just a suggestion, try asking a few questions FIRST before going to print because you look awfully silly when you have to correct yourself.
I have only looked at the first 3 links and the fullboost pic is an R31 series 2 or 3, not an R30.
Your specs are out to hell.
Engine: L24E (E represents electronic fuel injection)
2393 cc SOHC 6 cyl 12 valve
Power: stock 93.4 Kw @ 5600 rpm
Torque: stock 179 Nm @ 4400 rpm
Max Weight: 1250 Kg
There has never been an L26E or L28E, in Australia to the best of my knowledge, as both Z cars were carburetted.
You forgot about L16B, L18B & L20B, all 4 cyl SOHC 8 valve engines that came out in Datsun 1600's in the mid 60's, then 180B, 200B.
There was only one R30 that came out with a live rear axle and that was the van/station wagon and I have NEVER seen one in Australia. All Australian delivered MR sedans and hatches came out with R180 open diffs, 3.9:1 ratio.
DR & HR series Japanese Imports came out with R200 LSD's 3.9:1 ratio.
Will post again later if I find anymore anomylies
www.mr30.tk
thanks Josh
Quick correction:
Both the 260 & 280Z's Aussie delivered were carbie inducted, the L28E in Japan was an L28ET, that never came to Aust, to my knowledge.
Other than that it's fairly accurate Josh, all in all not a bad project, just a pity the research wasn't more extensive.
What you may have noticed, all USA 280Z's were our 260 body.
Bing-bong....your attention please Ghostrider  :D
I hope to have it engineered and emissions tested, registered etc by end of this year, but going off road straight after rego for HKS exhaust with ext gate, Trust inlet plenum, GT3540 turbo, and 3.5 inch system, FMIC etc, etc.
Other than that, how long is a piece of string?
Have to get an MR30 Ti hatch finished as well.
But rest assured, I will do a stop, revive, survive stop n Port for at least one day and will let you know when. Probably a Friday night, leave here 3ish and be in Port about 7:30ish maybe.
You plan on doing some cruising eh! :ghost:
Hey Josh,
Cheers, Mick.
Don't they WRECK them in Adelaide?????
If you want I could organise a gearbox & I have a pedal box spare.
All the ancilliary bits would come from the gearbox source.
Cheers! :ghost:
Hey Josh,
Cheers, Mick.
And remember when you cut the hole in the top of the airbox, your gunna suck in sh!t loads of HOT engine bay air. Great for performance as heat KILLS HP.
Hahaha....Ghostrider, YOU forgot the L13 and L14 that also came out in the Datsun 1600's obviously they werent called 1600's with those engines, they were called Bluebirds.
The L13, L14,L16 and L18 didn't have the "B" designation, either.
The earliest L series you will find would be a 1968 model as they were released in 1969.(Obviously they were being built before they were released)
Odd that his site is based in the netherlands too.....(or appears to be)
hole in filter box still okay tho since at least it gets some cold air through the snorkel thing. my pod is the biggest K&N thing they have and it just sits there and doesnt really get cold air from anywhere but i dont know how to do a CAI on a DR30 there isnt much room to play with and not any hole in the spoiler to feed a pipe or something up to it :P
south africa built R30 skylines.Like australia had 910.these had live axles.I also think that all short wheel base body[4 cyl SOHC had live rear].well I havnt noticed any difference removing air intakes.i assume the air filters not up to the job.as the car gets hot air from RH side AND MINE GOES HEEPS BETTER with water temps in the high 90's.
some of the Zcars,I think 280Ztarga, are efi.never seen a 260 EFI,the turbo wasnt a spec for australia.and some usa models have b/w T5.I think there is a spec difference from state to state in OZ untill 1988,also states other than NSW,VIC AND LATTER TAS had seporate distribution networks and in 1908's have different ADRS.280C have efi.I had planned to use a L20A,L24 twin carb in my holden many years ago,so i was looking at ADR complience and needed a L24E,L28E..
ooooh,sounds nice! Big HP here you come! lol
I don't know how long a piece of string is...what sort of string is it? :jk:
Friday night in Port sounds cool! Not that there's many good cars here that go out,but anyway.....
I always plan on doing some cruising,but no bastard ever want to go with me!!!
I'll be in Terrigal next sunday in the Skyline,on a cruise actually!
And just to be a pain in the arse again,that Mobil 75-90 synthetic lsd oil,was that like $74 for 5L(or maybe it was 4L) I went and loked at some today,but it didnt mention anything about being suited to lsd's.Didnt say unsuitable either,but Id like to be sure first. :P
tar
ohh yeah,
Cheers again, Mick.
yeah mick, with the exhaust i got rid of those 2 90degree turns and had a new cut out of the left hand side, and still looks good. I did not get extractors just 2 1/2 " throughout. There was a noticable power increase and there is a higher top speed. :wassup:
Thanks to everyone for your corrections, I will update the website pretty soon. Feel free to keep commenting.
Cheers
Josh
i was just in Port Mac up from Tas for 8 days (but not in my car), but saw r32(gunmetal with kustom plates?, an r33 and a pimpin red 200sx but thats it, cool place tho great beach and more laid back, not too hot and the chicks at roxys go off!!definately a place to stop on the way up north..
:aroused: Damn missed the thread.
newby alert!! got a HR30 sedan L20T 5sp all standard not many around need any basic improvements eg: FJ20 B'fly? 'cooler? anything? starting from scratch on this one!! :aroused: Woftam is just a club for guys who are too old to do anything else that requires energy!
Cheers
Josh
Are you aware that the 2 x 90 degree bends and subsequently the exhaust outlet being on the driver's side, is a result of Australian only, bureaucratic bullshit about protecting the pedestrian from exhaust emissions.
The Japanese car had the exhaust outlet on the left, directly out from the silencer.
Are you for real???????
At 90! I'm surprised you can drive a performance car at all.
My father is 89, and THE WORST god damn driver I have ever seen, holds an open license and is scared shitless driving in excess of 80 klicks.
I'm damned if I know how he manages to hussle the RTA each year in his driving test.
I suppose the theory is slow is better, as opposed to some youngen wanting to drive at the speed limit is an idiot.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
