  • Replies 2k
konis/kings, seems to be all right but will see as time goes by how firm the konis stay, a mate has them on his r30 put them in about 9 months ago and hes saying there are getting soft, his is a daily driver, mines gone 60km since the ignition was wired up, i can say cornering is flat and fast!!
anyone seen the second last page of the latest HPI mag as there is the whole page to the DR30, small write up not to much info what they do say though is stay away from a dr30 for under 10,000 and be prepaired to pay up to 15,000. Also i emailed the bloke about the RS turbo booklet and he said its in japanese, but he did say that hes got a 20 foot container of dr30 parts and panels plus a couple of cars comming over in march so if there are things people are looking for then he may be to go!!
ah yes that SA GUY....sed he had a dr30 diff he would sell me for $1300....wtf.
on the dr30 front bar issue, got a qoute for one ..800$ landed from that jenesis place
1300 on a r200 diff i quess??, the front bar quote is that through rezz or jenesis itself?
I haven't actually pulled the diff apart to look yet. It open wheels and twins up then opens again so it ain't in the greatest condition. Probably just shimming or drive plates just guessing. I wanna change ratio's as well but that could be expensive.
sounds very much like my diff, under load it twins, but free spin it has one going one way and the other spins the other way?? was told the diff in a pintara has the perfect ratio for track and was a good swap?? thats what i was told!!
boof- pm'ed stu-r30 with the details and seems hes done deals with him?? may be ask stu-r30 what he thinks??
Guest
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
