Whats the go for twin plates for FJ? New ones availible?
Umm i happened to stumble across mine whilst cruising round on FJ20.com..very lucky!! Managed to get OS Gieken with flywheel so pretty cheering!
Yeah i watched u take off the other sat Crimmo and the subframe must been close to hitting the deck son..Looks cool but wouldn't really be good i dun think!! :wavey:
  • Replies 2k
has anyone put in a autometer tahco in before? its just i'm having trouble getting a signal from the rb20 ECU, i've wired it up correctly but when the ecu tacho wire is connected,regaurdless of engine rpm, the tacho will go to 3000rpm and stay there. i've been told that the rb20 ecu signal is 8volts and the tacho requires 12volt but looking for advice from someone who has put one in themselves!! cheers... matt..
Someone!!!! please enlighten me, WHY??? would anyone want to fit an autometer tacho, when the stock one goes to 9000 rpm and can easily be converted to suit 6 cylinders and fits neatly in the dash instrument cluster.
WHY??? do you want a monster ugly thing sitting on top of the dash.
Other than the stock cluster that includes 260K Speedo, 9G tacho, volt, fuel, oil pressure & water temp gauges, I am fitting 2 extra gauges into the console, those being boost & oil temp.
Why you want more?
Id love to know how to hook up the standard tacho to the RB20... :starwars:
Im looking for a muffler, anyone know of something for sale that works well and is cheap, 2nd hand or new... at the moment im runnin 4" from the turbo into 3" all the way to the back where instead of a rear muffler, i have a resinator, its a tad too loud
cheers :stupid:
been looking at clutches also, as mine just packed up, got quoted $750 for a 5puk sprung centre, ceramic, 1050kg pressure plate from adelaide clutch service/extreeme clutches, thats brand new, and i rung again and asked for the price to rebuild that clutch and they said $640!!
A quick question for all people with FJ20DET powered DR30's.
The L20ET 6 cyl turbo is identical to look at in every way to that fitted to an FJ20DET, but the FJ has a 0.68 rear housing as opposed to the L20 0.37.
Q: How much boost will the FJ turbo take before it breaks???
cheers :stupid:
i got told 450 for a 1500kg clutch. not sure of the puks, centre etc..
from jap tech or something. the guys thats used to be Import Dismantlers
cheers :stupid:
I took my cluster to an Auto Instrument Repairer in Camden NSW and he modified the 9G 4 cyl tacho, to work as for 6 cyl, don't know what he did, but I saw it working on the bench. To get it working with an RB, my sparky says it will be no problem, so maybe the answer is a trick auto sparky and not D. I. Y.
As for exhaust/mufflers, plenty of S/S canons on ebay for about $120/$150.00.
But don't you have your system arse up? gases as they cool, expand and therefore need more space to flow at the same rate.
You have a 4 inch dump, going into a 3 inch system????? shouldn't it be the other way around.
I have for my big banger, a 3 inch dump, 1.75 inch from ext gate, feeding into a 3.5 inch front pipe, cat and back to a S/S rear muffler, 3.5 inch inlet and 2 x 3 inch outlet, as I want it to at least look a little stock from the rear.
Don't want to tell everyone in advance that they are about to be blown off by a 20 year old fossil. That may be more embarrassment than they could cope with.
Clutches: UAS has a 6 puk with 40% extra claping pressure they claim, will hold onto 300 rwkw and still be driver friendly for $695.00 exchange, with postage it may be the same as you have, but might be a little cheaper, but maybe better.
My set up will cost you some dollars, but in the end, a far better system. I have a billet steel flywheel (Castlemaine Rod Shop) $550.00, designed for 10.5 inch VL Turbo clutch (far cry from 9 inch Skyline) using a full KEVLAR faced plate and 1500kg diaphram in the pressure plate. Will be VERY driver friendly and hold over 300 rwkw.
A friend has a similar set up in his R33 GTR in QLD and has never had a problem holding his 300+rwkw. :ghost:
As for getting them to fit mate, speak with Crimmo he's done it on his car and will be something that i will be looking at doing on mine very soon!!  As for the R33 front's fitting in the rears, they just bolt up!!
Yeah im good mate, got a twin plate for the DR now, just waiting for that to arrive..Getting bonnet in week or two so gonna go look for some decent panels/bumper and away we go..Luckily i took the skirts off the front guards before the car went to the crash shop, so all i'll be missing is the front skirt..Easy as!!  Cars slowly coming together hehe!!
Hows your bus coming along??
33 front coilovers i can sort without a problem to go in the back
whats the amount of fiddling required for s13 fronts to go in the front? i really need to know exactly what is needed to make them fit
got my first look at my "brakes" yesterday - they are rusted to death so i really need this. 33 4 spots in the rear attached to the suspension and s13 ones in the front would be awesome!
as for my bus
painted without a polish and with some na 33 rims
off to workshop tomorrow!
Why you want more?
but it goes so well with the PRo comp extra lite boost, oil and water temp gauges i put in at the same time!!
P.s. i've had to replace the instrument cluster with the one from the mr30 as the other one was rooted, the spring for the speedo was all twisted and beyond help, swapped it for the mr30 which also went to 200km not 180km. plus later i will use a piVoT speed meter!
man that front is high!!!!!!!!!!, does anyoine know how low the fornt can be lowerd with out going coilovers. ive got cobra lows in there now. and the front didnt drop one bit :D well 18 year old springs compressed :).
Dude, it has no engine in it so theres no weight pushing it down.......
ive got 40mm strut spacers and lowered springs in the front of my MR and although it still has guard clearance (2 fingers) its pretty damn low, i was concidering going lower but if i get ths front spoiler i don't want to be a street sweeper
The factory minimum rad clearance is 160mm.
So! theoretically 60mm is as low as you can go, but that is at DRY weight. NO fuel, oil, water etc, etc and standard exaust.
If you have a performance upgrade exhaust, that could create 100mm minimum ground clearance problems.
My MR30 hatch has 40mm lowered rear and 50mm lowered fronts and that is still legal. Looks as low as, but still has guard clearance. Due to the spring rates and Koni dampers, there isn't a lot of suspension travel anyway.
Hope this helps. :ghost:
i've just put 225/50/15 tryes on the rear of my car and that has lowered it by 10mm 205/55/15 at the front which lowered it by7-8mm! it all adds up
Geez Matt,
You must love wasting money, if you have got that much the combo switch is now $1000.00 LOL.
Factory fitted tyres are 205/60 x 15 .. inflated OD 625mm, dynamic radius 304mm, revs per km 524 and recommended rim is 6, but can go on 5.5 - 7.5, my optimum choice is 6.5.
The tyres you have just fitted 225/50 x 15????
inflated OD 604mm & dynamic radius 293, revs per km 543 and recommended rim is 7, but is acceptable on 6 - 8.
NO WONDER YOU JUST LOWERED IT 10mm!!!! you have also stuffed the speedo accuracy by possibly as much as 10 - 20 kph.
If you had to stay with 15's 205/60 was your only correct option, if you want wider 16's are the go and 245/45 are perfect in all respects or another alternative is 225/50 rear & 205/55 front, all similar spec to 205/60 x 15.
Good luck with the law!!!! :ghost:
how did you lower it? with just shocks and springs. if so how did you over come with the limiting factor of shock travel in the front. mine has been lowerd approx 30mm. compared to a factory paul newman.
now i cannot go any lower without limiting the shock travel. e.g risking the fact of bottoming out, unless someone knows how low it can go. i have aprox 7-10cm of travel left in my shock. and thats just hitting replaced. "larger" bump stops.
The travels right, but I have put 250 lb/inch front springs with Koni dampers and I doubt wether I will get that much travel with these springs. An upgrade replacement 24mm sway bar has been added for good measure.
Considering standard front springs are 108 lb/inch, and mine are an increase of over 200%, I can't see a problem unless you go looking for the deepest of pot holes.
My HR30 Paul Newman has JIC Coilovers in all corners with even heavier springs and sway bars.
Guest
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
