  • Replies 2k
Yeah, but people keep throwing up 200hp figures for the Paul Newman which is bs... if that has 200hp my fj20 must have 300hp lol
Careful Adam,
You might be accused of being blasfamous, after all, my Paul Newman has a lot more than 200. LOL
Adam,
I think they quick, just depends on the comparison.
My mates in Adelaide tell me there is a Paul Newman down there, that after caning it's ass off, it does 15's at the 1/4.
Hold that thought for a moment, 15.??? second 1/4 time and have some consideration for our own aussie muscle. The 5.7 litre Monaro only manages 17's for the 1/4, off the shelf.
Compared to that! the Paul Newman is pretty quick eh!!!
Sams IS the Adelaide Paul Newman, its standard apart from a turbo that is apparently a "triple hybrid", filter and exhaust. Its bloody clean though, and it sounds sweet, but its slow. Sam reckoned that my car was noticably faster when he went in it... which is when it had a huge boost leak. And now that mine doesnt have a leak, its much quicker
How many are there in Australia now? When Ivan was advertising his he said there was only three... his, Pauls (now Sams) and another one that was in either Sydney or Melbourne
I still doubt that the Newmans had 200hp standard, or even much more than 145.
Shit, my Charade GTti must have been a monster... stock except for the exhaust it ran a 16.7 (granny launched... just drove it normally (ie sloooowly) off the line) but at 85mph lol
BTW Sam lives in the house behind mine :D
i think you'll find that the ones ghostrider and i are talking of are not STANDARD and you are on the mark with your stock power figures give or take! :D
you might be able to answer a question though! were the paul neumans released in 2 or 4 door version as my mates is a 4 door and he seem to think they were only ever released in the 4 door version??
hey all...i just bought a r30 hatch for $200....im gunna stick the motor/box(5speed) into my 1.2litre 2wd hilux.......can the ecu be modded or do i have to buy an aftermarket computer? i want to put headers and a cam in it.....btw the motor and box are A1
oh....bummer...how far can u go with these motors before needing to change the ecu? im guessing head work and pipes is about it?
if anyone read the ZOOM engine review then according to them the ECU can be played with?? but i think the problen is finding someone that has bothered with these engines here in OZ.
the trouble with the vane airflow meters, well in my mates case was that they flip wide open under boost and go to 9:1 A/F ratio.
thats why you see so many pulsar Et's blowing chaff
i think from memory you can basically adjust idle, mid and high mixtures
took my car to work with me on saturday, i know the trouble i could have been in, 40k round trip, all and all she went like a dream, one miner problem, no indicators!! it was something i had to do and was not disapointed!!
Fun arent they :)
I drive mine the looooong way to uni, go up through and across the hills instead of just cutting across town.. only takes 5 minutes longer, and its a hell of a lot more fun :evil
the thing is with mine its unregistered and i'm running an rb20det so its fun and illegal!! :sadam:
Guest
    • Sorry the pictures suck. So hard to get camera and light in there
    • One of the first jobs with the E39 is making sure the tailgate stays up. In BMW fashion they made a little cavity under the roof to hide the dampers rather than putting them down the side like everybody else.  As you can see I have these little cavities that house the dampers. When I cleared one out and vacuumed as much crap as I could out of it I noticed a fair bit of rust. The cavity is bone dry, even after all that rain we had only a few days ago so I'm assuming that whatever allowed the moisture in is fixed but I'd like to treat the rust in there.  I was thinking of just blasting it full of rust converter but I didn't know if this would be beneficial considering I can't actually get in there to prep anything.  Maybe there's a better product?  Thanks guys
    • Had a few skylines over the years anyway bought this a few years ago for skidz i think it’s been around these traps for a while anyway I plan to thrash and trash and I assume it’s going to send me broke good times
    • The stock boost solenoid is just a valve. Power it and it is open. Unpowered, it is closed. When it is closed, there is no boost bleed out through the solenoid back to the inlet. The wastegate sees all the boost pressure, thus you get the wastegate's spring pressure as your boost pressure. 5 psi. When it is open, it lets some boost escape. This causes the static (boost) pressure in the line to the wastegate to be lower than the pressure in the intercooler pipe. There is probably a small restrictor in the solenoid or one of its lines to limit the flow rate of the escaping air, which limits how far the static pressure can fall, which limits the extra boost. The boost has to climb above the original/wastegate setpoint until the wastegate sees 5 psi. You get 7 psi in the intercooler pipework. A manual boost controller is exactly the same setup, just without the ability to change it on-off. It's always set to whatever you set it to. There is a small leak from the boost controller. The more you screw the adjuster in, the more it leaks, the lower the pressure seen at the wastegate and the higher the boost will be. So, yes, your diagrams are correct.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
