I got a stock one, but otherwise get it made.
Your sedan got rear discs with it's IRS???
All hatch's have rear discs and they're interchangeable with sedan. Just attach at cross member, but if you do this you will need the handbrake cables as they are different to the drum ones.
nah got me a dr30 rear end. disc, calipers, shafts, everything except diff
  • Replies 2k
r31 gts front shocks etc with discs and calipers
rear is dr shafts (i think) but an r200 open wheeler which has stood the test of time for at least a year of second gearies
Same spec, just different offset on hubs.
Is yours pre or post 83?
82
You would have a TOKIKO style master cylinder???
If yes, there is a 1 inch upgrade available, don't know what vehicle it comes off, but if you took your old 7/8 m/c to a brake shop, or you know exactly what it looks like, get them to order you one.
Our 84/5's can only go up to 15/16 unless we change all the bundy tubing.
im not sure. the cylinder seems to be holding up ok so far. what are the advantages of changing it?
makes sense. z31 discs are the same as dr30's?
Same spec 274 x 22 as your R31 GTS.
We have discussed this topic extensively on another thread.
I have DR front & rear, slotted rotors and EBC green pads up front & black rear.
They are a high temp KEVLAR compound low friction, excellent road set up. But I am going to upgrade my fronts to BNR32 GTR 296 x 32 with 4 spot Nissan alloy calliper, only because I have, potentially over 300Kw at the wheels.
Anyone know if cutting a MR30 hatch grille (the eggcrate one with the three slats) so that the eggcrate crap comes out, effictively makes it the same as the other three slat grilles?
And if a set of coilovers were made for a 180B, they should bolt up to a R30 since R30 stuff bolts up to Dattos?
when i did the engine swap the machanic put the r32 master cylinder on mine, never had a peddel feel so good! with the hr brake callipars on mine i had to go to bendix comp X pads as EBC dont make front pads for these callipars...
Jenesis is www.r30.co.jp but when you access it put it through Alta Vista translation or similar so you can sort of understand what there saying in descriptions.
BUT! don't get to excited, they won't trade with you DIRECT, it's a good site to explore, and a lot of their parts can be made here just from the pictures. It is a good referrence site as well, to see what they do with them in Japan.
If your interested in getting some bits from them, it might be a good idea to put it to open forum discussion and we try and jointly get an order together and then get in touch with a parts importer, like Nengun, one of SAU sponsors.
Only one problem I can see with your car...... far too many doors!
i'd put my hand up for a group order from jenesis as there are a few body parts i'd like from them, i could speck to the boys at option 1 as they have have containers comming over each month...
Already done that, I talk to Nathan & Paul at least once per week.
Yeah i would be interested as well in getting some stuff from jenisis...I know in one of the earlier pages on this mammoth post that there was talk bout it, but that kinda died in the ass i spose...I wouldn't mind some of that bracing for a start that would rock!! Depending on what we can get and for what sorta $$$ it will all cost of course though!!
Geez,you've gotta be on the ball to keep up with this thread!! :D
Talk to Whiteline and they will tell you both rear tower brace and floor braces aren't necessary' date=' but Jenesis makes, sells & uses them, so! someone aint up to speed.QUOTE']
I thought it was still a good idea,even with a rear tower brace,as the mid-section can get a bit "flexy" with no B pillars...
Also,I may be interested in a engine dampener brace from Jenesis,depending on price.Does anyone know if there's something to do the job locally?
Guest
    • I did a bit of googling, the color MCM used was Galaxy Grey from House of Kolor. This is actually a colour I picked out about ~10+ years ago (or more). This one is a stock BMW colour, I guess over the years I figured it was smart to get an OEM colour that was pretty common for all of those sensible reasons one can think of..
    • I absolutely love having clean wheels and also totally love cleaning them. Its not as important to me to have a clean car exterior as it is to have clean wheels. So I bought a kit. I generally use different products for my wheels than anything else, so I thought I'd buy a proper kit and bucket to keep it all in. I got this one from Waxit. I also got the CQuartz wheel and plastic ceramic along with a bunch more application micro fibre pads as CQuartz never provide enough.  The kit was good, but as usual the big, long spongey thing didn't fit between my spokes, so I needed to use a detailing brush and a larger brush that I already owned (been doing this forever, the spokes on these wheels are frustrating.) I did a full clean with the wheel cleaner, it has an iron killing product in it, so I found that I could just use the cleaner and nothing else on the wheels. The tyre cleaner and handled brush were awesome. Made cleaning the tyres so easy. Once everything was clean, I decontaminated with isopropyl and applied the ceramic. Two coats. I bought 2 bottles as I have a lot of wheels to do, half of one bottle did two coats on these. The X5 has 20's so I reckon probably 3/4 on that. Then, for possibly the best part, the wheel cleaning kit comes with a tyre black applicator. But, this is possibly the greatest sponge of all time - its a great size, quite stiff and HAS A COVER! When you finish applying the black, you just put the cover back on! This is revolutionary, I normally have to try and find safe places to put my tyre black applicators as they are covered in silicone and tyre crap. Or, you use something which just falls apart. This applicator is the bee's knee's. Get one. It's worth it. The tyre black is also like a cream, its very thick but goes on really thin, its very easy to use with the applicator. Ayway, after a big clean, decontam, ceramic coat and tyre black the wheels went back on and they look awesome.   Thought I'd share.
    • Haha. Good work. I feel some of your pain because I spent a bunch of time under my car over the period too. Probably nowhere near as much as you did. My happiness is similarly improved by obtaining a desired result though. Those side skirts are.....hecking. Very unfriendly for street and hoist. Sounds to me like you've made a cart that needs to be driven up only planks/blocks at a 2 post hoist, rather than trying to get it up onto a 4 poster. It's very pretty, by the way. Somewhat reminiscent of Marty's squid ink on SuperGramps - at least in the photos.
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
