r30 skylines
rsx84
 Share
ADJUSTABLE REAR SUSPENSION
Baz from DatSport in Adelaide will modify or make up the jig to make the R30 Suspension FULLY ADJUSTABLE, if we can get 8 people willing to get the job done.
DO WE HAVE EIGHT (8) on this forum that want's the job done????????
whats the $$ involved, i spent over a $1000 on my suspension before this thread was started, i just look back and laugh now, haha haha crap....
  • Replies 2k
put me down as a definite
as for the spool centre, im in for that too. just make sure u get strong as f*ck half shafts.
possibly a good relationship with your local tyre dude aswell hehe
Can we have it shipped/trucked up here?  And any idea how much that would cost?
3:00am Ghostrider do you sleep? lol
1. You would have to get your cross member and rear trailing arms to SA.
2. After modification they would then be reshipped to QLD.
3. 0300, I am a security consultant and work a lot of nights.
4. American Beer? get a few GMD's into you, a six pack goes down like water, but it kicks like a mule.
R30 POLO SHIRTS
How many members of this forum, ACTIVE on this thread would be interested in our own R30/SAU POLO SHIRT, if we had one made up.
you know i'm in for one...when would you need an answer on the adj rear end?
Can anyone recommend a good Aussie intercooler?? I've priced up DNA + Hybrid + GCG and they are all roughly the same price. Im hoping to fit a GTR size behind my standard front bar (600x300x76 core size).
All the places I have contacted have not been able to give me an exact pressure drop
(I figure it will be about 2psi) or tell me if they have been bench tested. I think DNA will be my final choice, as I have heard good things about them.
I have thought about using a standard R32 GTR intercooler as many people recommend them, but want the w**k factor of a nice new, clean and shiny intercooler behind my front bar. I've been told that R32 GTR coolers only have 0.5 pressure drop across the cooler and that if they were S**t, they wouldnt use them on a GTR, but I'm not convinced.
Re the Shirts - I'd be keen for one - what colour and design????
i went with the hybrid as i got it for $600+postage brand new, i read on the powerdigger site that the hybrid 600x300x75 intercooler had "0.5psi loss at up to 40psi" and can cool around 500hps' worth of air flow. hope that helps!! had the piping made from 2 1/2" press bend mild steel for $450 installed, all up about $1100 fitted..
I would be keen for a shirt.
As for the adjustable rear, I am very interested, just can't be sure of it at the moment, getting a bit of work done to my car at the moment and a bit low on funds so it would be good to know how far away this would be happening.
Alright looking to put coil overs in my car. I see the easiest option to be an s13 setup, changing to a macpherson strut setup in the front using s13 hubs and so on and going to R32 style brakes at the same time. Anything wrong with my thinking here?
Also for the rear I remember reading someone has put s13 rear coil overs in a R30, I just can't seem to find the post, I was just wondering if they bolt straight in or is some type of modification needed?
I have only really had a quick look at a silvia suspension setup so I'm no expert.
Also interested in the replacing of the boots as mine seem to have dissapeared over time, but for a DR30
Cheers for any help
the S13 rear coilovers fit up all good except they are either 2 hole at the top at the back, whereas DR30 are 3. basically u have to drill an extra hole to line up the S13 coilovers at the top. pretty simple job though. just stick one thread in an existing hole, then drill a one that matches up on the other side. i havent done this to my car but todd with DR30 on these forums has, im sure he will pipe up soon to confirm what i just said :rant:
i mite be interested in a shirt depending on it's design and price i guess.
Guest
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
