  • Replies 2k
I'd be up for one of them, Mines got a bit of damage which I have just bogged up. So that would be good.
I'm currently looking into making a fibreglass bonnet for my car. Not sure how well it will work but atleast it will give me something to do.
what style are you thinking as id put up some $$ for an iron mask drift style one :wassup:
do you have pics for this drift style iron mask?  would be interested if it looked the goods. :mad:
i'm thinking along the lines of those twin inward air ducts that allows more air flow through the radiator, think i posted a pic of a r31 version ages ago, i'll try to find a pic of what i'd be looking for in a bonnett :):)
i'm thinking along the lines of those twin inward air ducts that allows more air flow through the radiator, think i posted a pic of a r31 version ages ago, i'll try to find a pic of what i'd be looking for in a bonnett :mad:  :)
Yeah I was thinking of something like a big backwards vent for more air flow. But yeah as I said I don't know how this will work, My mate does a fair bit of fibre glass work and is gonna give me a hand so have to wait and see.
Ghostrider
I havent taken them yet :mad:  Law and managing a Blockbuster is leaving sfa time atm
plus I accidentally deleted your pm with your email
Shit eh! Blockbuster Manager????? hope you do it better there than they do it here.
I do all the security work for them here in Campbelltown, Narellan, & Minto (affectionately known as minnow, by the houseo's)
So we see them eventually eh!
I'm going to punch a couple of dozen louvres into my bonnet
hm my cars a DR30 iron mask turbo but has no vent in the bottom left. just normal front .. i often think i wish it had some kind of hole for air to get up to the Pod filter .. i had an NA front spoiler on my S13 so i cut like a grille style thing into the bumper to let air to up there a bit... not too keen on doing that to the DR though! :(
saw a couple of carbon fibre bonnets on Jap websites for DR30 iron mask ... thatd be damn cool ! costly though id imagine to buy a bonnet from jap and get it brought here :D i think i converted the cost at the time and it was like $850 to begin with before freight and tax and gst and watever else :)
']what grille? im confused? haha u mean that small bit of metal beneath the edge of the bonnet with 2 rectangle holes in it?
and how would u open that up nemore!? haha
just need like a Jenesis style front spoiler with big opening on it :(
Just hang in there for a while longer, I will probably be turning them out by the end of the year.
JENESIS style front bars
yes, your front grille.  Rather than messing with the bonnet, why not think about altering the grille?  Anyways, just thinking about costs.
You obviously don't know what a DR Tekamon grille looks like, otherwise you wouldn't make this comment.
AND [ant] it's fibreglass not metal!
ah fibreglass right. mine has a few chips touched up so it looks sorta metal but then yeh it does have a slightly different colour shade to the rest of the car so i guess that explains it =] mine rattles like all hell wen u tap on it and over bumps sometimes but i guess thats the metal sortof retaining thing inside of it making the racket !
Guest
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
