  • Replies 2k
']i have a DR30.
yeh the diagrams on FJ20.com are the 2 that are no good. its a 2 page diagram of the ECU wiring. i need the full wiring diagram with fuel pump etc on it.
OK,first thing you must have is a test light.If you had a burning smell first check all your fusible links(on mine there is 3 at the battery and 4 at the fuse box)
The fuse box (drivers side firewall) contains all your fuses and relays including your fuel pump relay.If all your fuses/fusible links are ok you should have power to all the relays and the fuel pump relay should click off after a few seconds with ignition on.If all is ok connect your test light to the fuel pump and with ignition on or engine cranking you should have power to the pump.
Try that and see where you end up.
Todd
Yeah I was thinking today that I want to be able to see the screen easily as I'll use the speedo function (will calibrate with a GPS) so I might put it on top of the steering column inside a tek box so it looks like a Jaycar digital speedo.
Does anyone know how that annoying 114kmh beeper works? Does it just get a signal from the ecu when the car exceeds 114, or does it recieve the speed signal?
whats the device that makes the beeping noise?? is it standard or after market?
ADAM,I'm not sure if it runs off actual speed,or just an ecu output,as you say.At a guess,I'd say it runs off the speed sensor wire,the units in HR31's do....
What I am sure of,is if you want to compleatly remove the whole 'ding' module,and stick it in a postpack I'd be more than happy to shout you a couple of beers :rant: or send it $10 COD.... I WANT ONE!!!!!!
What I am sure of,is if you want to compleatly remove the whole 'ding' module,and stick it in a postpack I'd be more than happy to shout you a couple of beers :P or send it $10 COD.... I WANT ONE!!!!!!
I may have a spare one lying around, ill get back to you on that one
My mate has an S13 180SX and he can't change the sensor, but the beeper itself simply attaches to the back of the speedo by 2 screws.
He removed the beeper/speaker and NO MORE NOISE, but you have to put the screws back, something to do with open circuits, as others have removed the beeper, left the screws out and had problems with the speedo fluctuating.
well i went outside today to my car to pull the dash apart and look for any burnt wires but decided before doing that id open the fuse box and turn ignition and listen for any of the relays ticking over to try and find fuel pump relay.
anyway, turned the key and *bzzzt* pump was back to life. power was back to it again. i then turned it on and it was super lumpy and rough. checked the pressure guage and it was reading 41psi idle pressure rather than the 34psi i set it to the day before before it died. then found out that the guage, rather than sitting on zero, was actually sitting another 1/4 of the guage face further down, below the vacuum area (guage had vacuum bit on the bottom 1/4 of it). so it was probably about 15psi out or so :P so wen i connected it initially and thought it was at 19psi, it was probably at 34psi like i wanted. and then wen i turned it up to 34psi, it was more like 50psi idle pressure. so wen i took it for the 2 spins round the block, it must have just overloaded the system and thats y the wires were burning. ECU must have noticed and cut the power to the pump at this point i guess.
so i connected another guage, disconnected the 2nd air valve thing that i had hooked up yesterday when it was at the wrong higher pressure, and got some new plugs since the old ones were all fouled up, and it sat and idled perfectly at 34psi idle pressure.
so just gota take it for a drive tomorow and see how it goes, see if it still has the huge misfire that it had and if it starts to get too hot and short the wires again. hopefully no permanent damage was done but we'll see tomorow i guess!
Its located underneath where the head unit goes in the '30s I think.  If it gets a feed from the speed sensor wire then that would be quite useful
Its to the right of the cig lighter, those three lines/slots in the plastic allow the noise to come through, is a little metal box behind the slots.
Oh tell u what got a surprise the other night, opened the fridge to get some mayo out and the bottle behind it had a familiar face on it!
It was baltic or balsamic vinegar and it was Paul Newmans own brand!!!
sorry totally off topic and random, just surprised me and Ghostriders signature trigger me
was driving home this morning from a mates place and saw an all black hr30 2door driving the other way, big ass fmic taking up the whole front centre, sounded rotoraryish big on lumpy noise, turned around to try to flag him down but lost him?? so looks like these another 2door r30 on the coast, about bloody time...just have to track him down...
Guest
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
