  • Replies 50
+ 1 to the shock and spring combo! i use KYB shocks with whiteline "low" springs. resonably comphy ride but still stiff enough to give a nice feel to the car. altho you wont be able to do that for a few hundred $$ lol...unless you someone manage to find them all 2nd hand maybe.
got told wrong info from someone else :(
fair enough, just to clarify, we have coilovers standard, so they cant be illegal. the illegal part is height adjustment, now what ive been told is that what clarifies as height adjustment is when the height can be altered without adding or subtracting parts from the suspension, although id imagine the interpretation would extend to not being able to adjust the height without pulling them apart.
im going to try and get through with my combo (bilstein/eibach), we'll see how it goes, ill be slipping a non threaded seat on top of the threaded sleeve, this will make it technically legal as u would have to pull the suspension apart and take parts out to adjust the height, even though theres a adjustable sleeve on it, its useless.
imho i dont think 8kg front and 6kg rear are too stiff
i could possibly go a wee bit lower maybe 7-5 you never know
but yeah harsh spring rates could actually casue you to loose grip
8kg and 6kg is probably the highest you want to go on a strret car! i personally reckon that is already a rough ride and my coil overs are progressive spring rates
Damo's right bud. If you speak to suspension gurus like SydneyKid etc, they'll steer you towards 5kg or 6kg fronts and 4kg or 5kg rears with aftermarket adjustable sway bars for track work.
Your tyres are already going to give you a harsh ride due to the profile. Even on the track, the whole idea is to stop the body roll hence the bigger (adjustable) sway bars. The Japs love to put 8 to 12 kg springs on their cars which is fine if you have the glass tracks of Tsukuba etc......problem is, our tracks aren't the best in the world and hitting a slight ripple in the bitumen on a bend or whilst braking at the end of a long straight may see you come unstuck.
I was actually having a similar conversation with Andrew (Blue32) at my place on the weekend where people spend huge money on big dyno numbers to go faster around Malalla yet a properly setup Porsche with alot less power can still embarras some Skylines........even having the biggest brakes on the track would be next to useless if there's no rubber making contact with the black stuff.
EDIT: If you ever get a chance, place a Bilstein shock alongside a well know Jap shock and have a look at the difference in valve bodies.....you'll be surprised at how good the European stuff is.
Another thing that I fail to understand, Bilstein have 9 degrees of adjustment as opposed to some manufactures that offer 16 or even 32......what are you (the average guy) gonna do with 32 settings?.......can you really tell the difference between setting number 23 & 24, LOL?!
ey mate just to let you kno. bring the ADR papers that are posted on a thread here with you to regency. if you read them, nowhere in there does it say that coil overs, adjustable or not, are illegal. Therefore you can leagally have them, ive heard its just a unwritten law at regency that you cant. If they do say something, be polite:D and tell them that no where in the ADR papers does it have that coil overs are illegal, and then just ask for some written legislation somewhere if they persist. My mates have gotten through wid adjustable ones heaps of times. Just make sure the height is legal and you'll be right with the suspension. Just dont hold me to it but defiantely read those ADR papers ive read em a couple of times and cant find anything anywhere
the ADR form in the defected thread leaves a lot of stuff out, which might get u out of a defect from a police officer, but the regency guys know their shit. what i said was what i was told from regency.
ok but out of curiosity ask em for the actual legislation, the actual paper work. because as i said some of my mates have gotten through regency.
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
    • I bought my Bride reps from Crank Motorsport. He is, um, a trifle disorganised. I would have to look back at the e-mails to make sure I got it right, but I think he sent me normal fabric ones when I ordered the "Alcantara" ones. So he had to pay for shipping 3x and I'm sure that f**ked him off big time. And asking technical questions where nuanced English is required is a no go. It's simple English only. And....should I have bought the Alcantara ones? Well, as it turns out, they are great, feel great, etc, but the fabris wore through on the point of the waist bolster in <2 years. Must have caught a rip from a rivet on jeans or shorts, or something like that. So now I have to patch it somehow. A bit shit. My fault, ultimately, because it is Chinesium Faux Alcantara, not the real thing, and it turns ot that it has the tear resistance of a soggy tissue. But the seats and the reails are great. I probably should have gotten the R34 style ones, and now that they price is up in that ridiculous sort of number, I could have sold them for a profit!
