CES/SWG Ceramic coated split dump for R34 GTT
Used for about 30,000KM
Will Not fit any GTR nor R32 nor R33
Made from stainless steel, flanges are perfect, fitment as you'd expect is perfect.
Pix can be arranged but I dont particularly see why you'd need photos. PIPE - $150
Also - EOI On a Highflow turbo for any skyline will bolt up to a t3 flange, has new actuator and has produced 261.3RWKW with Camshafts on my R34 Neo. Internals come from a GT30 Full boost by 3500RPM Still is on vehicle but I am concidering buying a bigger turbo, MUCH BIGGER :(
Turbo has traveled an expected 15,000KM or LESS! I would like $1500 For the turbo. Turbo is still on vehicle, EOI currently. Buyer can place a deposit if that keen.
Please dont offer me any less than these figures. I did not expect so much want for these items so to let you know Pickup is unavaliable for at least 5 days sorry
Cheers.
Edited by DECIM8
interested in the turbo. when will the turbo be off the car and wat boost were you running to make 261.3rwkw (dyno sheet)? also does it come with water/oil lines?
thanks
Edited by Just_Rb
No I dont have a print out, but you can ring Yavuz at Unigroup to confirm just was in there today talking about next choices.
Yes I suppose it will come with oil + water lines depending when i get the new turbo.. Will be out of car when I decide to upgrade depends if you are serious about the turbo then perhaps this can be pushed forward.
PIX ARE NOW IN
TURBO OFF THE MARKET FOR ALEAST 2 MONTHS. THANKS.
$150 GUYS - BEEN AWAY ON HOLIDAYS SO SORRY FOR THOSE WHO HAVE WAITED SO LONG TO GET A PM
P.S THIS PIPE DID NOT HIT THE WASTEGATE OR ANYTHING OF THE SORT.
Edited by DECIM8
hi just wondering if dump pipe is still available. also if post is available or is it pick up only.
also i have a couple questons first if its ceramic coated does that mean i wouldn't have to heat wrap it? also you said it doesnt hit the wastegate does that mean you never had a problem with boost creeping with it? also were you running the 261kw with it? last question, is it a 3 inch piping?
sorry for all the questions just getting as much info as i can on dump pipes. and this is the best one for a r34 ive come across so far.
thanks.
scott.
Hi Scotty,
Yes Postage is avaliable, just have to find a odd shaped box lol.
You should not heat wrap stainless steel, it has been proven to crack at the welds in some cases. Ceramic coating does a similar job however increases flow for the exhaust (less resistance in the pipe) and yes it does resist heat to perform like heat wrap.
With this dump pipe I made 260rwkw no problem with boost creep, looks like they got the combo right!
Hey guys,
Sorry ive been very busy this dump pipe is avaliable to sydney/NSW buyers only sorry I just dont have the time to post it any more.
Please contact me via PM
P.S for everyones knowledge its the dulled pipe with two seperate pipes under the super shiny new one.
Edited by DECIM8
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
