car info
TUNED BY STATUS TUNING
302rwkw at 1.5 bar car makes full boost 1.5 bar at 3,900rpm
all wiring has been cut to size, to ensure no eletronic problems
i am the vic motul rep so only motul oils have been used throughout the car.
1999 Nissan JDM silvia
79,xxxkm
Engine:
SR20DET
Trust Td06 l2 20g
Trust high mount manifold
Trust 48mm external gate
Trust dump and front pipe
Trust sump
Blitz pod filter
Nismo engine mounts
Ikeya formula intake plenum (quad throttles)
Ikeya formula fuel rail
Tomei rocker arm stoppers
Tomei 1.2mm head gasket
Tomei head studs
Tomei pon cams 256in 256 ex
Power enterprise 800cc injectors
Greddy pully kit
Trust 13 row oil cooler kit with remote mount
Trust LS front mount intercooler
Fwin dual layer radiator
SFS radiator hoses
R33 clutch fan
Trust petir titanium cat back
Apexi evc
Nismo intake fuel pump
Split fire coil packs
Trust oil cap
Cas cover
Sard fuel regulator
Speed flow fittings and braided lines
Drive train:
Nismo 6 speed transmission
Nismo super coppermix clutch
Nismo lighten flywheel
Nismo GT LSD
Trust diff cover
Wheels:
Volk 57s pro
18 x 9 +12 toyo t1r 225/35/18
19 x 9.5 +12 ironman 235/35/19
Trust wheel nuts
Brakes:
r33 gtr brake master cylinder bm57
Front
Trust front 6 pot callipers
Trust 355mm rotors
Trust pads
Trust braided lines
Rear
R33 drum handbrake conversion
Trust 4 pot callipers
Trust 330mm rotors
Trust Braided lines
Electronics:
viper 1002 alarm
Apexi power fc d-jetro (map sensor)
Blitz id-3 boost controller
Defi control unit 2
Defi oil temp gauge
Defi boost gauge
Defi exhaust temp gauge
Greddy incabin damper control
Suspension:
Greddy type S coilovers
Nismo front strut brace
Nismo rear strut brace
Nismo front lower control arms
Nismo rear lower control arms
Nismo front sway bar
Nismo rear sway bar
Uras front cast rods
Tien tie rods
Cusco rear camber arms
Cusco rear toe arms
Uras rear subframe bushes
Body:
Full genuine Vertex lang kit
Resprayed in house of kolor white with white candy
Spoiler holes removed and de badge
front and rear guards flared
Interior:
Bride zeta 3 driver seat (red)
Bride zeta 3 passenger seat (red)
Bride driver sl seat rail
Bride passenger sl seat rail
Bride door trims
Nardi deep corn steering wheel
Nismo gear knob
ENJOY
also car is for sale !!
Edited by 180athid
https://www.sau.com.au/forums/topic/257679-march-fast-fours-my-car/
  • Replies 44
Posted Images
very nice mate.. surely you can keep it and buy a house aswell... you wont get what its worth so you may aswell hang on to it... these days you can get a 95% loan anyway.
and who is the fast fours photographer... they always have good photos.
cant beleive you are selling it already athid... it was only a year ago that you were soooo excited about getting it...
hell of a lot to do to a car in a year aswell!
gl with the sale :)
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
