Well the turbo is mounted on the right hand side of the engine bay. So to keep wires to a minimum in the engine bay and to avoid running the wires across the firewall or across the front of the motor follow the wires into the passenger side footwell and run the wires across the back to where you wish to mount the EBC. Don't drill a hole in the firewall, looks awful and its just downright lazy.
there is a rubber grommet in the firewall at the drivers footwell.
a coathanger and tape is your friend from there.
that side is chockers, thinking passenger side... will go have a stab when i can be arsed
and right hand side looks to be the go-er haha
lazyiness kicked in, didnt put EBC in, but put my informeter back in, just need to work out what o2 sensor voltage is what AFR, save money on dyno run :D
My turbo's on the left hand side of the engine and when I pulled the loom out of my wreck I had to remove the abs and aircond so I would be into drilling a new hole (with a new grommet of course).
i saw the spot behind the ABS and decided i rather come back upstairs....
All RB20/25/26 CA18 and SR20 motors have the turbos mounted on the right hand side of the engine (looking from the front of the vehicle) or passenger side if you could so call it. So unless you have a toyota motor sitting in there, all inline nissan import motors have the turbo sitting on the right hand side.
good post sothern tango....
stop being lazy :) turn full lock to the left i think... pull out yourwheel arch and thread it threw... its super easy dude
ps SEARCH IS YOUR FRIEND
i may or maynot of chopped the front half of my inner guard out :)
could you elaborate or take a phone snap shot of where you mean? or suggest search keywords
when i was installing my ebc i used the grommet shown in the pic southern tango posted,just jack up the drivers side front and remove the black plastic inner guard (four screws if memory serves) and some elbow grease,u cant miss the grommet which already has the main fuse harness running thru it in towards the steering column and firewall
  • 4 weeks later...
i installed my UHF with the door open and through the quater panel ..... and into the engine bay running along the rubber seal for the bonnet.
but then again that is a UHF different storey :P
in my old skyline i ran a Batt wire for the sub through the steering colum rubber thing ..
but then again that is a UHF different storey :)
driver side is chockers :blush:
you did the UHF on the passengers side?
A rather late reply but generally left and right relates to sitting in the drivers seat - you will notice that parts that are labelled left and right ( such as lights, seats, doors )follow this convention i.e. passengers side is left, drivers side is right - thus turbo is on the left, steering column on the right etc.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
