Had the 100k service done at Boostworx yesterday, belts, water pump, all fluids, diff, gearbox, attessa, brakes etc. I did my own oil and oil filter so that wasn't needed. They also fixed my dodgy front/dump pipe install and reseated the O2 sensor properly (didn't quite go all the way in before due to wrong thread on JJR's pipe). Car is now running like new, purring along beautifully, gear changes are much quicker and smoother. Couldn't be happier. If anyone has been putting it off, do it, do it now, worth every cent! They also put it on the dyno, 135rwkw. Total cost incld. 3 new bulbs, $1050.
Just thought I would share. :D
EDIT: Forgot to add that they changed the plugs too (supplied by me)
Edited by webng
https://www.sau.com.au/forums/topic/257716-just-done-100k-service/
  • Replies 49
I'm a huge fan of Shaun, Troy and the guys at Boostworx.
Took my GTR there for it's first service + 100k stuff. Had it dyno'd and everything. Got it back and it ran alot better!!
Just recently got a brake upgrade done by them, too.
And will soon be back for more work!
+11789239923645928598256 Boostworx
Yep mines a RS4 (AWD) but their dyno is only 2wd so they dropped the shaft. Shaun mentioned 135rwkw is normal for the minor mods mine had, with all running well. Shaun and Troy have a couple of new guys there too, another mechanic (Andrew?) and an aprentice mech (Alex?). Both good blokes.
They're still pretty busy but at least it's not that long a wait to book it in now! What I like about them is I don't have to worry about them ripping me off, they'll only do the work required and charge accordingly. A bit of a hike from where I am (Payneham) but well worth the trek. I only wish they have eftpos! Cash only hurts the bank like crazy. :D
my stags going in on the 3rd for its 100k... lookn forwood to seeing what it pulls..
there doing my 100k, ebc and safc install and tune for 1800.
im guessing its a little diff for the 26... im thinking i might try and get my hands on all the stuff and just get them to do the labour part.
my gf's brothers 180sx is their waiting to have the rb20 wired up, auto elec quoted 3k, boostworks quoted 500!
Mines off getting serviced at Road & Track... theyre close to my place (Enfield)
Getting all fluids dumped, flushed and replaced
Getting all filters replaced/cleaned
Getting new sparkplugs, injector seals and injector clean
Getting diff seal tightened, brakes checked, dyno run
Dunno if there was anything else that needs doing (they'll call me) but I can't wait... come on 5pm
-D
What are they charging?
-D
I won't know until i get the car back, but around the $600 mark.
Got car back. Loads of stuff done today....
New Globe, oil and fuel filters, air filter cleaned, NGK platinum plugs fitted, new diff oil, new brake fluid, new steering fluid, new hicas fluid, new engine oil. 3 leaking injector seals replaced, injectors sonicly cleaned, tyres rotated, rocker cover retensioned
came out to just over $700 :)
BUT
I have to now
replace front rotors, replace front brakes, replace LH Rear crossmember bush, remove radiator and get it completely flushed out, leaking injector replaced, and 2nd hand r33 gtr gearbox fitted. Probably gonna cost me over $1500 including parts but I don't skip so I'm gonna grab new RDA slotted front rotor and get some bendix ultimates to replace my current ones cause I'm pretty happy with them....
then (if I get my contract renewed) get some 2860-7's, nismo FPR, tomei poncam-b, hks cam gears and a radiator shroud purchased and fitted at the same time I get my n1 water pump installed :)
Fun. but not for my wallet.
-D
They're still pretty busy but at least it's not that long a wait to book it in now! What I like about them is I don't have to worry about them ripping me off, they'll only do the work required and charge accordingly. A bit of a hike from where I am (Payneham) but well worth the trek. I only wish they have eftpos! Cash only hurts the bank like crazy. :)
yeah im a fan i was sure you had dyslexia with your power figure and meant 153 not to worry
i come from st agnes to go there so almost half the distance again of how much your travel
the young fella isn't Alex but cant remember his name atm
BUT
I have to now
then (if I get my contract renewed) get some 2860-7's, nismo FPR, tomei poncam-b, hks cam gears and a radiator shroud purchased and fitted at the same time I get my n1 water pump installed :D
-D
If there is any advice i can give ya mate
dont get the bendix pads....save some money and get lucas pads
bendix put out shitload of brake dust compared to the lucas
and lucas brakes better and can operate at a higher temperature
ร—
ร—
