Hey Al, that looks sweet! How is the display screen mounted in where the ashtray used to be? Have you set it up so that you can just pull it off? Only asking cause was thinking of putting my boost gauge in there, but worried about how to set this up, in case one day I need to change stereo systems or something, and need to get at them 2 screws in there...
Whistla:
I will change the screen to display the bar graphs and explain it is just a rev and oxygen display :rofl:
To make the factory solenoid work over 10psi, my mechanic had to play around with air flow restrictors in the vaccum line to the wastegate. He kept swapping restrictors till he was in the ball park, then simply tunned the wolf till the boost was steady at 13psi.
95GTST:
The two screws have not been refitted, so the surround simply clips off. The gap that you see in the photo is as bad as it gets (hardly noticable in the car).
Behind the black face is a piece of 3mm perspex, that has been cut and shaved to size. Then a rectangle hole was cut in the middle, to allow the display to squeeze through (tight fit) Once display was aligned in perspex a drop off glue was applied on the corners. Then the perpex was fixed to the trim by some more glue. Measurements were then taken and a neat cover was made, to complete the job.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
