Since i've bought my r32 gtr its been a lot more laggy than my mates, its not really full boost til 4500-5 and doesnt kick in that hard
My mates seems to kick in real hard down low, about 2500 from memory
Mines still stock turbos but its got adjustable actuators on the turbo's, ive adjusted them to run 10 psi and there seems to be heaps of pressure holding the internal gates closed, one thing i noticed is it hasn't got the boost restrictor in it but only runs 10 psi maybe still the actuators are adjusted wrong even though theres a lot of pressure keeping the gates shut?
It also has a big cooler but surley that wouldn't cause that big of difference in lag!?
Its got stainless dump pipes that go to a 3.5 inch exhuast not that i see how that would make it laggy lol...
apart from that its stock
Any ideas?
cheers
https://www.sau.com.au/forums/topic/257782-gtr-too-much-lag/
Might be worth putting some stock actuators on it then? but there seems to be heaps of pressure to hold the gates closed!
Full boost by 4000? wonder why my mates spools so quick then, his does have adjustable cam gears but i didnt think it would of made 1500 rpm difference
If your mates one has adjustable cam gears that may explain why his ramps onto boost harder and faster.Cam gears properly dialled in can increase low end and spool up.not too sure as to what extent however
hey mate, same kinda thing i found with my gtr stock everything except for zorst, full boost by 4000rpm atleast, not a reall kick in the back either... untill i boosted her to 15pound, made a world of difference,cam gears are going in atm so hopefully that will help lag.
but yeah adjustable actuators on stock turbos not so sure, maybe put factory ones on and save ur self time mucking round.
ball bearing turbos help too.... :)
FWIW my stock turbos + EBC make 13 psi by 3300rpm, but has Nistune. Saying "full boost" without quoting the boost level is meaningless because the higher boost the longer it will take to get there... but yeah 10psi by 4500 is no good. I'd try a set of stock actuators first.
byebye - Did I fit cam gears to your friends GTR? That will make a big difference..
I would suggest getting it tuned/diagnosed properly.
Sam.
Cam gears were already on it but you played with them, its the blue sparkly/dented one you tuned at munros before power cruise
The timing was out a little bit and has made it slightly more responsive
When are you coming back to tas sam? nath did ring you one day but you sounded busy, you said something about him being a pest haha
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
