I need to claim back some shed space so I will keep updating the list of parts as I except the fact I cant keep everthing
Bare r32 gtr front cut suit crash repair.....$500.00
r32 gtr front end hubs, control arms, ps rack, complette.....$400.00 or will seperate? pm me
gtr sump modified for rwd (was in my rb26 vl) $400.00
hks pods and adaptors suit 32-33 gtr...$150.00
r33 gtr turbos...(poor condition suit rebuild).....$100.00 pair
rb25et ser 2 motor from stagea new water pump but has blown head gasket.....$800.00 or will seperate? pm me
stagea radiator suit r33gtst also..$150.00
r32 gtr radiator......$150.00
r32 gtr engine harness (has been chopped easy repair)....$80.00
r33 gtr standard rods and pistons only 25k old....$300.00
stagea standard awd auto and transfer worked perfect before removal...$300.00
r32 gtr 5speed box and transfer (no shifter)....$800.00
r32 gtr abs unit ....$200.00
r32 gtr brake master and booster......$250.00
r32 gtr clutch master and booster.......$200.00
hks pod suit gtst afm.....$100.00
3"dump pipe from r33 gtst has had repairs and a flex added looks agricultural but works....$75.00
Trust twin 2.5" twin system suit r33 gtr was running (twin td06 tubos) goes into single 4" at the diff flows big hp....$600.00
Trust twin td05-06 high mount stainless manifold suit rb26....$800.00
gtst r200 4.1 lsd centre...$300.00
various misc parts from r33 rb26 engine and r32 front cut left overs ask I may have what you need
I will add pics as I can or pm me your email, will listen to all resonable offers. parts are in brisbane south I will post at buyers cost. call or text 0431787453 Thank you.
https://www.sau.com.au/forums/topic/257796-shed-clean/
hey bud after the speedo drive out of the 32 gtr box stz in brissy sell them for $45/$55 or new is $110 so iff you will sell it i am keen only going a second hand one as the car see's the out side of the shead to a trailer once a mth and a quick strap the street once every 2 weeks cops dont like my car now
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4450481
pm sent
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4459038
Do you have the standard Nissan R32 GTR ECU? If so how much?
Also do you have the stocko injectors? Need one or 2 to tie me over til I can afford upsized injectors...
I have an r33 gtr ecu and a mines r32 ecu the mnes is tuned for fuel pump 600cc injectors mine afms and hks 2530 turbos, the only injectors I have are upsizes which I have people in line already.
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4459041
I have a Mines ECU already in my 32 but stock injectors, which is why I need a stocko... But the R33 GTR fits the 32 gtr anyway, so if its stock (no chips/remaps) and you have that still, then how much you wanting?
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4460489
Sorry to pull out, but another guy came through first, so I don't need the ECU anymore. Good luck with it though..
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4461396
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
