I need to claim back some shed space so I will keep updating the list of parts as I except the fact I cant keep everthing
Bare r32 gtr front cut suit crash repair.....$500.00
r32 gtr front end hubs, control arms, ps rack, complette.....$400.00 or will seperate? pm me
gtr sump modified for rwd (was in my rb26 vl) $400.00
hks pods and adaptors suit 32-33 gtr...$150.00
r33 gtr turbos...(poor condition suit rebuild).....$100.00 pair
rb25et ser 2 motor from stagea new water pump but has blown head gasket.....$800.00 or will seperate? pm me
stagea radiator suit r33gtst also..$150.00
r32 gtr radiator......$150.00
r32 gtr engine harness (has been chopped easy repair)....$80.00
r33 gtr standard rods and pistons only 25k old....$300.00
stagea standard awd auto and transfer worked perfect before removal...$300.00
r32 gtr 5speed box and transfer (no shifter)....$800.00
r32 gtr abs unit ....$200.00
r32 gtr brake master and booster......$250.00
r32 gtr clutch master and booster.......$200.00
hks pod suit gtst afm.....$100.00
3"dump pipe from r33 gtst has had repairs and a flex added looks agricultural but works....$75.00
Trust twin 2.5" twin system suit r33 gtr was running (twin td06 tubos) goes into single 4" at the diff flows big hp....$600.00
Trust twin td05-06 high mount stainless manifold suit rb26....$800.00
gtst r200 4.1 lsd centre...$300.00
various misc parts from r33 rb26 engine and r32 front cut left overs ask I may have what you need
I will add pics as I can or pm me your email, will listen to all resonable offers. parts are in brisbane south I will post at buyers cost. call or text 0431787453 Thank you.
https://www.sau.com.au/forums/topic/257796-shed-clean/
hey bud after the speedo drive out of the 32 gtr box stz in brissy sell them for $45/$55 or new is $110 so iff you will sell it i am keen only going a second hand one as the car see's the out side of the shead to a trailer once a mth and a quick strap the street once every 2 weeks cops dont like my car now
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4450481
pm sent
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4459038
Do you have the standard Nissan R32 GTR ECU? If so how much?
Also do you have the stocko injectors? Need one or 2 to tie me over til I can afford upsized injectors...
I have an r33 gtr ecu and a mines r32 ecu the mnes is tuned for fuel pump 600cc injectors mine afms and hks 2530 turbos, the only injectors I have are upsizes which I have people in line already.
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4459041
I have a Mines ECU already in my 32 but stock injectors, which is why I need a stocko... But the R33 GTR fits the 32 gtr anyway, so if its stock (no chips/remaps) and you have that still, then how much you wanting?
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4460489
Sorry to pull out, but another guy came through first, so I don't need the ECU anymore. Good luck with it though..
https://www.sau.com.au/forums/topic/257796-shed-clean/#findComment-4461396
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
