hi all!
was in a carpark the other day, was standing near this car when all of a sudden it beeped twice at me!
wondering what/which sort of alarm this is, is this just a microwave sensor or something?
have also seen those ones which actually tell you to step away from the car, but id prefer something a little more subtle such as the beeps
really wouldnt mind this feature...
thanks!
https://www.sau.com.au/forums/topic/25780-alarm-with-microwave-sensor/
cool! where can you get microtech in sydney
never heard of it though...basic features for $800 sounds a tad on the expensive side though? hope it comes with 3 point immobiliser at least though...
is it possible to get proximity alert hooked up to any alarm?
hmmm, think i may check kmart out hey...
ok... im not trying to advertise for them. but they have some good features.. in fact i didnt like the way they installed it, thy cut some tube that runs into the door and it looks like some sort of seal, also the car phone doesnt work anymore, so a few call backs but still..... the guy we called was andrew (got him from a dealer) 9553-9342, 3 point immobiliser, auto arming, windows up, hijack mode (remote kill switch) turbo run-on, proximity sensors. ECT
I think microwave sensors does the same thing. Not sure if it is the same as the microtech proximity thing tho.
I remember reading my alarm manual and there were options for internal and external microwave sensors.
This just sense movement insider and outside. You can set the proximity of the outside movement, when to beep.
LeonT. I'm not sure if there is an alarm that senses noise in car. Maybe your mates Rex exhaust was loud and the alarm was sensitive to the vibration. My car sets off alarms in carparks when it echo real bad.
Not sure about the alarm telling you to 'step back', you might come back with a big key mark along your care. But it is pretty cool.
skylineakt, seriously..I was shouting @ my friend near the car and it'll beep a few times, it's weird...it detects sound..the rexy was parked in a city carpark, pretty funny though as I was shouting @ the car and it does warning beeps on me :D
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
