Hey fellow Skyline friends.
Was using my aircon the other night when it died.
got it checked out and found it was the compressor.
Does any1 have a compressor to suit an Rb25DET R33 skyline..
Need it pretty quick as its getting to over 40degrees here in rockhampton.
Cheers.
Michael
https://www.sau.com.au/forums/topic/257805-rb25det-aircon-compressor/
My aircon shat itself about a year ago because i never used it, which causes the seals to dry out. Now it's summer i really want it going again, particularly since my car is black. An aircon place here in Cairns told me that sending mine off to be rebuilt (in Brisbane) and back on my car will take about a week and $1500. I asked if i should buy a 2nd hand one off ebay and hope it was in working order and he warned me that any aircon that has been off the car for a while (as unused) is likely to seize up anyway because of the seals, and will therefore require a rebuild in most cases anyway. As my car is simply my weekend warrior i have no problem losing it for as long as it takes but if you need your car day to day perhaps buy one and have it freshened up first, then book the car in to have the work done when convenient. I have watched compressors go off on ebay for $30.
oh rightio. I see...
I cannot get a compressor from anywhere here in rocky.
700 bucks fitted and all that jazz if i can find a compressor..
Is turbo model engine the same compressor as the RB25DE??
Because repco can get 1 of them but not for a turbo. Just curious.
The weather here in rocky is TOOO hot not to have the lovely skyline climate control.
Cheeeers, Michael
I dunno if they are interchangeable. Stick to what you have would be the safest bet. I have a series 1 and wanted to buy a series 2 compressor because it had much lower k's when removed from the car but the seller told me that the pipes were different sizes so i decided against it. you have an r33gtst s1 correct? next time i find a cheapie on ebay i'll post you a link. there are plenty of skyline wreckers in the brisbane area that would have a better idea than i do
I can confirm that S1 and S2 compressors are different sizes, i have a S1 but i managed to fit a S2 compressor on by using bigger O'rings..
i wouldnt advice this but i had no idea what series compressor i bought..
hope this helps. :P
I have a turbo R33 A/C compressor sitting here unsure if it is series one or two. I got it for free from a wrecker down here when chasing one for a R32 because he wasn't sure if it would work or not and just so you know the inlets on of the pipes is a think 1-2mm bigger on the R33 for then the R32. The biggest problem for a compressor would be postage as it is heavy as hell.
I know of Mark Gibbs Panel House which is just off Moss Street near me (Logan City). I can't remember how much it cost me to get my R32 compressor sent up from Nisswreck in melb as I had alot of trouble finding a working R32 one.
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
