ext is for the exhaust, int for the intake cam.
they are used to retard or advance the cam timings....
if i am not mistaken only need exhaust wheel and need it retarded by a 2 to 4 degrees...but depends on your set up of course may need both....
https://www.sau.com.au/forums/topic/25783-hks-cam-gears/#findComment-547539
The general rule is -4 degrees retard exhaust, +1 degree advance intake.
The Nissan NVCS on relevant models limits what you can do and generally, things are ok as they are on intake.
I gotta admit two pretty coloured intake wheels under a plastic cover sure looks pretty.
T.
https://www.sau.com.au/forums/topic/25783-hks-cam-gears/#findComment-547547
