Overview:
The N1 Vision wireless router offers an easy way for you to view your network's broadband speed, computer bandwidth usage, and the status of your connected devices - all from an easy-to-read display.
Packaged in a new sleek and sophisticated design, N1 Vision offers the best in networking performance with its wireless 802.11n* 3x3 radio design and wired gigabit ports. The N1 Vision wireless router continues Belkin's commitment in providing the best user experience in the home market through its Plug-and-Play "CD-less" installation and simple network security setup.
Features:
Interactive Status Display shows your network's broadband speed, computer bandwidth usage,the status of connected network devices, and more. Plug-and-Play CD-less setup Easy Security Setup with support for Wi-Fi Protected Setup™ and Multiple SSID 802.11n draft 2.0 compatible - 3x3 radio design provides excellent speeds and complete wireless coverage 4 Gigabit Ports
Specifications:
Browser Based Management Browser Based Management
Link Rate Up to 300 Mbps in 20/40MHz Channel Mode
Maximum Users 253 (LAN), 16 (WLAN)
Patent Pending LCD Connected Devices , Download/Upload Speedometer , Guest Access Network , Network Display , Usage
Plug and Play Setup Plug and Play Setup
Ports WAN-- 1 Gigabit Port LAN-- 4 Gigabit Ports
Range Up to 1,600ft*
Security Wi-Fi Protected Setup; WPA, WPA2-Personal, 64-bit/128-bit encryption, Multiple SSID
Specifications Standards IEEE 802.11b , IEEE 802.11g , IEEE 802.11n draft* , IEEE 802.3ab
VPN Support IPSec pass-through , PPTP
looks almost brand new.
all cables and softwares included.
RPR $399
asking price $250
Edited by isr3
https://www.sau.com.au/forums/topic/257906-belkin-n1-vision-mimo-modemrouter/
  • 3 weeks later...
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
