Hey guys,
Whenever I come to a stop my car will idle fine, but then after a few seconds it will drop and the car stalls.
Sometimes it won't stall and it kicks back up to normal again.
Previously my R34 was running fine, yesterday I bought a cannon muffler and got it installed, and it didn't have the problem beforehand.
I took it to my mechanic and he reset the ECU but I'm still having the same problem, he then increased the idle to 900 but still it drops and comes close to stalling (but hasn't stalled on me with the increased idle yet).
Has anyone had this problem before? Can you please help me diagnose the problem? :blush:
Any help/advice?
https://www.sau.com.au/forums/topic/257920-idle-dropping-car-stalling/
I'm not a mechanic, but if you took it to a mechanic who simply increased your idle i would search for a new one! I would start by checking your afm and give it a clean with spray on contact cleaner (available from dick smith etc)
I have no idea, but remember it could just be a coincidence. Don't kill hours trying to solve the problem based on the muffler install, start with simple, cheap 5 minute checks and see if it helps. If you had installed a full exhaust that was much more free flowing and had an oiled pod filter the extra air drawn through can put oil on the afm and cause false readings. While this may not be the case, it is where i would start before doing more time consuming things, which is why your mechanic tried simply resetting the ecu before anything else like getting the spark plugs out and checking for fouling etc
Once again though, I'm not a mechanic
its gotto do with back pressure of the exhaust if its related to the cannon, was the old reonator removed and replaced with the canon? ive got a feeling its the 02 sensor and the ecu combined, I had the same problem in a manual r33 gts-t.
My solution was partly due to a number of things...
i cleaned AFM,
Changed spark Plugs,
Cleaned throttle body....
gained alittle more power and car stopped stalling, but it would still drop almost to a stall at roundabouts and stuff....
i ignored the problem since it didnt complertely stall anymore and just thought its an old engine....
i changed the 02 sensor from the original nissan one to an EL falocon 02 sensor for $70 from repco, cut the wires and tied them together and replaced the old one....not only did i gain an extra 100-200km/tank but to my surprise my revs stayed constant at idle and never dropped below 700rpm no matter how i drove it...
most likely your 02 sensor is broken coz they meant to be changed every 40 000km anyway. you will spend $70 on a falcon one like i did or $200ish for nissan replacement part, either way you will definately get your money back by saving fuel over a few months...
see if that works, and if it doesnt, the money you save from fu3el with the 02 sensor will help you to pay a profesional to find the prob...
its located at the beginning of your exhaust pipe just after the engine....
100% the O2 sensor is dead, my car is doing it right now as well and has happened a few times in the past. Change the sensor and everything runs like new again :down:
Which O2 sensor? And where is the O2 sensor located? (car is a R34 98 Automatic, 4door non turbo)
The 02 sensor is located on the exhaust manifold. If you're not too good with wiring etc - best stick with a genuine 02 sensor :D
Also check for vacum leaks (vacum hoses) and the main intake pipe between the afm and the throttle body - make sure its on firmly.
While you're at it it is a good time to clean the throttle body too.
  • 11 months later...
mate belive me,
try these steps.
before u stops the car put it into N. see how u go. if it not stall that is ur Automatic Transmission.
just chk ur fliud level. 100% its too low. top up with fluid in between L-H make sure to not to over fill.
see how u go.
if not, dont waste your time with doing crap.
possible case is ur TCC Solenoid in the auto box. it is not a expenvice part. [$50-70] if u have a skill u can do it by ur self. other wise take it to good transmission repare workshop.
if u in sydney PM me i will tell u where to go.
Hey guys,
Has anyone had this problem before? Can you please help me diagnose the problem? :banana:
Any help/advice?
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
