Hi all, got the stock plumback BOV and everythin on my series 2 r33...has the standard rb25det...jus so that people know what they are dealin with....
i want the flutter noise thru my pod/airbox/air intake...whatever u want to call the setup.....
all i have is mass suction and then a massive whoooosh sound......but i want the flutter sound to come out instead...as it sounds better and all...but im not sure on which pipe i need to block or what exactly i need to do to the stock bov and piping to achieve this....
so can someone plz tell/show me....pictures would be greatly appriciated for this.....
need any more info jus ask...hope someone can help me out....
i have read that this will cause the car to stall....true/false???
Cheers
Matt
n.b. : i dont need the lecture that flutter is good or flutter is bad....i have looked into it and i know the consequences etc.....
https://www.sau.com.au/forums/topic/257935-flutter/
easiest way to do it is get piece of 2mm alloy sheet and take the blow off valve off where it mounts to the cross over pipe and place the pipe on the sheet and trace it out and cut it out and drill the 2 screw holes in it and place that in there instead of the gasket. That way it still looks like a gasket but the air cant get to the blow of valve and gives u the flutter sound.
https://www.sau.com.au/forums/topic/257935-flutter/#findComment-4437248
thts the dumbest thing that u could do as it will f**k up ur car the way that it makes the flutter sound is by instead of releasing the air thro the blow-off it sends it back into the turbo and that will make ur car run lean u'll get shit fuel consumption and constant staling.
if u want the noise then get a screamer pipe any of the tuning shops will be able to do it its a lot better then blocking of ur blow-off.
https://www.sau.com.au/forums/topic/257935-flutter/#findComment-4437311
ive got a turbosmart mega sonic BOV and apexi super intake pod filter on my r33
i get the flutter and a stadard bov cshhh sound. changes depending on the boost it hitting. but with my flutter, i have free reved the car while watching the piston in the bov and see the piston bouncing to make the flutter. tried putting a plate where the bov is and it sounded shit.
so id say get a aftermarket bov and a pod filter. unsure of other ways but mine has done 0 damage.
i had the stalling problems but cleaned my AAC valve (DIY section) and increased the idle to around 800rpm and have no problems with stalling anymore.
https://www.sau.com.au/forums/topic/257935-flutter/#findComment-4437351
No offence, but your an idiot and have no idea what your talking about.
It won't make the car run lean, it actually richens up the fuel mixtures with a blocked off valve on the stock ecu, so will run rich for that split second.
What the hell does a BOV and screamer pipe have to do with one another? They are completely different things. Do you even know what a screamer pipe is?
Mate do a search on "flutter", its been covered a million times.
Thread lock?
Edited by PM-R33
https://www.sau.com.au/forums/topic/257935-flutter/#findComment-4437436
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
