  • Replies 44
Yeah i'll take one. email me with details, i got a 2003 V35 two door, i live in Geraldton WA
Hi Paul,
I had sent the email to you yesterday. The parts is been sent out by Courier Please shipping company. It take about 5 working days to deliver from Brisbane to WA.
Cheers,
ADam
So what are the results?
"Well I did the dyno test. My car is "Stock". Did 3 runs, I got 163kw on 2 runs and 162kw on one.
I couldn't put the Spacer on becasue the car is too hot, I'll put it on tomorrow then do another run on monday.
Here are my results of my best run"
Ok. Just put the Spacer on and went for a drive........
can't hear any sound difference or feel any power difference.
If there is it must be small.
I'm also guessing that if you have better intake, pod fillter and exhaust then you would notice the difference in sound and power. But since i don't we will wait for the dyno test monday.
Just thinking... it looks like not one small mod alone will give you any noticeable difference in power but when you have a combo of mods the gains seem to show.
Pic of the spacer and cover on..... and the hood closes...just
in the instructions it said i didn't have to.
But i'll do it anyway.......if i knew how
I'm not sure what the story is with V35s but with my old R33 there were two methods of reseting the ECU:
1. disconnect negative terminal and pump the brake pedal until all charge is lost, this should drain the charge quicker and reset it,
and
2. there were a couple of pins that you could short from the console test socket for a few seconds while the key was in the Ign. position (but this you'd have to research if possible with the V35)
So did you go off that YouTube video as a reference for installing Paul?
Edited by Pulp
To install i used this link http://forums.nicoclub.com/zerothread/274245
Didn't have to reset the ecu :devil: all worked
Ok the results were good i got an extra 7kw to the wheels
Check it out :thumbsup:
cool excellent mate! good to hear! :devil:
I think I will definitly be doing this, I have already got the exhaust and intake done so hopefully will add a little more power to the mix... :)
The people who make the spacer say that with there exhaust and spacer you can get 18hp to the wheels so with an intake aswell you could have some real noticeable power gains
Oooo.... and i get my bodykit this week too :thumbsup:
Nice 7kw @ the wheels is a good gain for such a basic mod on a NA engine :)
look foward to picking one up for my car when I have some spare cash to splash... got to build a new home computer 1st
Hi mate,
We got that in stock. last 10 to go for the next shipment. The price $390 Plus shipping.
Cheers,
Adam
hi mate,
Thank you for posted the dyno graph on here to let everyone know about the gain you got. Hope you enjoy the products.
Cheers,
Adam
cool excellent mate! good to hear! :)
I think I will definitly be doing this, I have already got the exhaust and intake done so hopefully will add a little more power to the mix... :down:
yes mate. with skunk2 intake plennum and combine with other mod like air intake system and the exhaust system will gain more than normally.
Cheers,
Adam
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
