needs a new motor. $300 or so ex nissan.
how mechancal are you?
For all we know Chris, this guy could be the 6 million dollar man!!
(Bionic.....for the younger folk.. :P )
Hope you're well buddy.... :)
Bump!
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4438432
I'm 37 I remember both shows.
reason I asked - if he's mechanical enough to pull the door down then he can change the motor himself. its mainly 10mm bolts (lots of them) that have to be removed.
failing that - take it to nissan and let them do it. the motor is a Z33 item and door (although SLIGHTLY different shape) is a Z33 as well. expect a $500 bill (inc motor) for that. to tear one down and reassemble is 1.5 hrs roughly. (thats what it takes me.)
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4438513
yeah...I knew that you knew that I knew that too! :) ...er....yeah!
Though with the current exchange rate, Bionic Man is prolly 7 and a half buh..and the door motor about 6 mill. :P
Good advice mate.
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4438633
someone is proud of their product. they are not that expensive. last one I bought new was $350 locally.
nidn you since its tore down I would also do the regulator as well. saves tearing it down again. the reg is the worst part of it.
give me a chassis number to work with and I'll pull a part number for you. there is a revison on that motor as well. looks like they fixed what broke in them.
Edited by Chris Rogers
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4439124
Thanks guys! and Chris specially!
i got told yesterday, before i go purchase a new one, to open it up and clean out the surroundings of the buttons....anyhow will let you all know how i go.... if it doesnt work, i will just go to NISSAN and get a new motor...
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4439425
I tried "reconditioning" mine first but I think the problem with them is something else. After cleaning it up it would work going down but didn't have enough strength to close the window. Just put in a newy, it's a new part number so hopefully you won't have the same problem.
1.5 hours is reasonable I think if you stay focussed. 4 hours? you must of had a few beer brakes
Edited by Blitz_boy
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4440461
someone post a shot of the inner door and I'll do a point and explain.
stephen,
never looked at the FSM for this thing. I dare say its 4 hrs from dry though. (to do a doot lock actuator does take longer - thats a BITCH to do!)
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4441336
Oh, yes maybe I was thinking door lock actuators... not window winder.
Anyway, I still take my time, hate doing things twice, bescause I didn't locktite something, or adjust it, clean or polish it.
As for Beer "Brake" (sic), nope never during... just a Bourbon as I finish the job.
So Chris, the first one you did would be 4 hrs would it? It is just you have experience now though!
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4445382
Hey Guys.
Ever had a problem with the windows moving while driving at high speeds (110kmh+)
My windows shift up and down when go over a bump or past a road train. The "open doors light" comes on aswell as the door lights and interior light.
Any ideas?
I think i might be to do with some sensor thats a bit touchy.
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4467957
  • 1 month later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
