needs a new motor. $300 or so ex nissan.
how mechancal are you?
For all we know Chris, this guy could be the 6 million dollar man!!
(Bionic.....for the younger folk.. :P )
Hope you're well buddy.... :)
Bump!
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4438432
I'm 37 I remember both shows.
reason I asked - if he's mechanical enough to pull the door down then he can change the motor himself. its mainly 10mm bolts (lots of them) that have to be removed.
failing that - take it to nissan and let them do it. the motor is a Z33 item and door (although SLIGHTLY different shape) is a Z33 as well. expect a $500 bill (inc motor) for that. to tear one down and reassemble is 1.5 hrs roughly. (thats what it takes me.)
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4438513
yeah...I knew that you knew that I knew that too! :) ...er....yeah!
Though with the current exchange rate, Bionic Man is prolly 7 and a half buh..and the door motor about 6 mill. :P
Good advice mate.
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4438633
someone is proud of their product. they are not that expensive. last one I bought new was $350 locally.
nidn you since its tore down I would also do the regulator as well. saves tearing it down again. the reg is the worst part of it.
give me a chassis number to work with and I'll pull a part number for you. there is a revison on that motor as well. looks like they fixed what broke in them.
Edited by Chris Rogers
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4439124
Thanks guys! and Chris specially!
i got told yesterday, before i go purchase a new one, to open it up and clean out the surroundings of the buttons....anyhow will let you all know how i go.... if it doesnt work, i will just go to NISSAN and get a new motor...
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4439425
I tried "reconditioning" mine first but I think the problem with them is something else. After cleaning it up it would work going down but didn't have enough strength to close the window. Just put in a newy, it's a new part number so hopefully you won't have the same problem.
1.5 hours is reasonable I think if you stay focussed. 4 hours? you must of had a few beer brakes
Edited by Blitz_boy
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4440461
someone post a shot of the inner door and I'll do a point and explain.
stephen,
never looked at the FSM for this thing. I dare say its 4 hrs from dry though. (to do a doot lock actuator does take longer - thats a BITCH to do!)
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4441336
Oh, yes maybe I was thinking door lock actuators... not window winder.
Anyway, I still take my time, hate doing things twice, bescause I didn't locktite something, or adjust it, clean or polish it.
As for Beer "Brake" (sic), nope never during... just a Bourbon as I finish the job.
So Chris, the first one you did would be 4 hrs would it? It is just you have experience now though!
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4445382
Hey Guys.
Ever had a problem with the windows moving while driving at high speeds (110kmh+)
My windows shift up and down when go over a bump or past a road train. The "open doors light" comes on aswell as the door lights and interior light.
Any ideas?
I think i might be to do with some sensor thats a bit touchy.
https://www.sau.com.au/forums/topic/257981-window-problem/#findComment-4467957
  • 1 month later...
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
