cough cough i nearly bought a mint condition series 2 just before last christmas for $22000 NZD but i only had $17000 and 260rs is almost too unreal for a first car . so i bought an RS four S
Yeah well maybe you all better check the Yen/Dollar rate.
This accounts for most of it.
Autechs are now running around 1.4 - 1.7 million Yen. A lot cheaper than a year or so ago.
The exchange rate means that landed & on the road, they are a fair bit more expensive.
Even 2 years later my car (still selling at over a million yen in Japan) would be more expensive today!!
I aint complaining though!
Any Autech in the mid to low 20k's is still pretty good buying. See what the equivalent Skyline sells for.
It's only this economic downturn that has made the market fall, that and maybe a glut of cars on Australian roads.
Anyway, anyone that was serious buying an Autech should have bought RBNT's......... bargain of the year!!
That price also includes 12months rego, 3 yrs warranty, 12 months roadside asistance, free delivery anywhere in Oz. Take all that away i reckon you'd be able to drop the price down.
Edited by webng
makes me want to buy a rb26 twin manifold, modify to suit rb25, and bolt on 2x gt2860rs disco potato's :D
manifolds $300 for new stainless rb26 pair plus old rb20 headers
modify for $200 at most
3x 3' Y exhaust tubes $60
2x 5bolt Gt dump pipes $240
2x dual bb gt2860rs $1800 with lines
welding and cutting work...
so around two and a half grand (to 3 grand tuned & finished) would be enough for the above products......
bolt on manfold, bolt on turbos, use T junctions in water & oil lines, bolt on dump pipes, cut current dump pipe, weld 2x flanges onto Y exhaust piece and weld onto dump, join up exhaust
use anouther Y exhaust piece to join up the 2x turbo intake to the afm and pod filter, and the other to join to intercooler.
bit of metalwork and mucking around so you'll need some custom welding done, trial and error fitment...
but thats my current thoughtline......................... :)
:P
uh-huh :P
with all my work so far would make the rb25dett almost as good as a worked rb26dett, considering it'd be a $40k car all up @ end of project
Yep, it was a good deal. Its sold now and is on its way to the new owner, who has been very patient (weve had weather dramas) and is waiting for his new toy with baited breath.
mine had just over 500hp atw, was great fun if not a little mental. THe new owner will have a ball with it come winter.
Ill change the avatar when the new car arrives (its a shed toy)
Edited by RBNT
I bought mine 3 and half years ago for $35k (yeah I know, cheap hey), I spent another 35k on it and did around 5000km after doing the work. It was a shed pony hence the reason for selling it, wasnt going to appreciate for some time.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
