Hey guys, was wondering if someone could shed some light.
What are the options for MILD STEEL dump pipes only? I cant seem to find anything at all. For stock turbo might i add.
Currently have the stock dump pipe bolted to a 3" HKS front pipe. So im not after a front/dump combo.
Will i be better off having something custom made?
Im about to get it tuned, and according to the SAU gurus, theres alot to be gained over the stock restrictive dump pipe so wanted to get it done before the AFR tidy up with SAFC2.
Thanks alot.
https://www.sau.com.au/forums/topic/258061-r33-gts25t-dump-pipe-options/
Why does it have to be mild steel?
Plenty of one, two piece and one piece split dumps in the trader section, all bolt up to the standard turbo, mine is a one piece split dump from jjr and im very happy with it.
grab a JJR and cut off the second half, or sell the HKS front pipe
So i might as well just get one made? Dont want to sell the HKS front pipe, as the good stuff doesnt sell here. Everyone in NZ wants the good shit for the cheap shit price.
The reason i want mild steel is because i have already had a JJR stainless split front/dump combo. Had nothing but trouble with boost spiking even after modding so the wastegate flapper opens properly. And apon removal, the stainless stripped my 02 sensor thread and it took 4 hours to remove from the turbo with a gas torch. Not willing to try the stainless route again unless it is a high quality item and not cheap stainless.
What is regarded as good quality stainless? Im not sure what the numbers and grades mean.
if you already have the HKS front pipe then you might as well get the HKS dump that will bolt up straight to it with no mods required at all.
Id get one if i could scource a genuine HKS dump pipe. How can you tell if it is actually genuine? And who stocks them? Struggling!
could check out the GKTECH dumps? i got a split dump/front combo and they are two seperate pieces.
Thanks dude, just looked at their website and they dont look bad. Any problems with boost spike on the stock turbo? I dont want to go down that route again!
Thanks for the replies guys.
Edited by gotRICE?
I have heard people mention those problems, i must have been lucky or maybe they work better with the vg30 rear housing i have.
AM Performance make a range of high quality, locally made, performance split (return or screamer) or bellmouth style dumps. all are made out of stainless (not 304 which is shit) and is guarenteed NOT to crack. straight bolt on fit.
Here is mine, its a screamer and as you can see, goes into the turbine itself as to seel it from the gate side of things... wont leak on idle.
AM Performance can be contacted on [email protected]
Hey dude, have you looked up Tomei dump pipes? Theyre in a similar price range but the Tomei is the bellmouth design.
Heaps of stockists in welly.
I got mine from Soichi @ ST-HITECH up here in auckland. If you run out of luck, ring him up and he can sort you out! PM me if you want his number.
Try www.nengun.com
They should have them in stock.
Good Quality product as well
Extention pipes.. no wonder i never found then on Nengun!
But @ $511.. flag that. Its over half of what i paid for my full HKS High Power Silent from them! :blink: Economy FTL.
304 Is stainless... Its a number which refers to its metallurgical composition. 304 is your general purpose Austenitic stuff you see everywhere for food grade places followed by 316 which is a bit better. The best grade to use for Exhaust is 409, a Ferritic stainless with no nickel content, instead it is stabilised using titanium.
I think the problem with the chinese stuff is that although they may say its 304, its either full of impurities or its composition is only loosely based on the proper ratio of Carbon, Chromium and Nickel to make it. Personally I'd suggest using Mild steel for all the flanges or machined surfaces if you're going to use 304 to avoid warping.
Sorry to rant, I use stainless for everything where I work, so thought it should be cleared up.
yeah no probs mate, i know 304 is stainless, but my "its shit" comment refers to the fact that its not really any good in an exhaust application that sees rapid heat cycles. 304 is what most china dumps are made out of, hence the cracking issues.
AM performance dumps are made out of 316 manily and 409 is optional if you wish to spend a bit more.
have used 316 exhaust from the turbo back on my R32 drift car, for many meets, which saw lots of heat cycles, making 280 rwkw and never ever had a problem.
Bevan: http://www.fortyone.co.nz/parts/view/16848.html
Isn't Mac doing a 20% off thing? That would make that about $380? Not quite so crazy. Or get one of the Ds at Midas to make you one up, I was happy as with my stock turbo one and the one with my GT30R seems to be doing the trick too... both made by Dan.
Edited by Lithium
wewt. I heart you Dan. Will get in touch with him.
Although 4-6weeks shipping? Maff
Edited by gotRICE?
Argh don't speak too soon - I pondered the terminology and I would get Mac to confirm that he is talking about the same thing though, I always took the "Front pipe" bit to be what connects to the rest of the exhaust though he describes it as connecting to the turbo.
He has a separate entry for "Extension kit" and no description of what it is, but is advertising it at $690 - or $552. Eek.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
